F40 trans fluid
Wheres do you put in the trans fluid in an f40 transmission? Currently working on a ldk/f40 swap and i just noticed i have no idea where to pour the trans fluid in and where the drain is. Thanks!
No problem that's to fill on the bottom of the trans you should see the drain plug to drain you cant miss it. And that's a regal trans for reference
