Fuel economy
Fuel economy
OK.. if you put the smaller pully on the SC with a new exhaust and a high flow cat, theroreticaly this will increase your fuel economy. Is this true?
It depends I think on how its set up. If your running more boost, usually you are consuming more fuel, otherwise no more boost would get in. On the other hand if your MAF records the difference and compensates, or you change your MAF setup, you could either run better fuel economy or at least the same.
