Help Installing Lambo Hinges
Old Dec 5, 2011 | 06:17 PM
nutty21's Avatar
K, got them on there.
Open and Shut fine.
How the hell do you get the Rocker Guard back on?
Hinge is in the way where the rocker guard indents.
Can't get the thing back on no way no how.
Old Dec 5, 2011 | 06:42 PM
SneakyMilo's Avatar
No.
Easy Fix: Remove lambo hinges. Re-install stock hinges.
Old Dec 5, 2011 | 06:45 PM
cobaltss#01's Avatar
pictures might help
Old Dec 5, 2011 | 06:51 PM
nutty21's Avatar
Looking for someone that's done this before.
Old Dec 5, 2011 | 06:59 PM
05Slowline's Avatar
lol ew
Old Dec 5, 2011 | 07:03 PM
nutty21's Avatar
Yeah, staring to be eww.
Don't know why these things don't fit better.
I get the need to cut the inside of the fender, since that's where the henge is,
But I'm not getting why they couldn't make it so the rocker guard fits..
What'd everyone else do here?
Old Dec 5, 2011 | 07:11 PM
05Slowline's Avatar
not buy lambo doors lol
Old Dec 5, 2011 | 07:14 PM
JL-KA's Avatar
Pics of what you're dealing with. Not many people have seen them.
Old Dec 5, 2011 | 07:18 PM
nutty21's Avatar
Well it's all together and I have a rockgard that won't go on straight, so picture a rockgaurd that has something bushing on the inside of it so it won't site properly.
Not much to look at honestly. It's altogether and just have the hinge pushing on the inside of the rocker guard so it won't fit in there properly.
Old Dec 5, 2011 | 07:20 PM
JL-KA's Avatar
Simple answer seems to be to notch the rocker guard. Is that not possible?
Or grind what's interfering a bit?
Old Dec 5, 2011 | 07:30 PM
nutty21's Avatar
If I "notch the rocker guard I end up with a hole in it and then the water, etc, will come of the wheel and just go right in the fender/door.
Can't grind the henge.
SO I'm really confused as to what other did here.
Old Dec 5, 2011 | 07:45 PM
nutty21's Avatar
bUmp
Old Dec 5, 2011 | 07:48 PM
PsychoCam's Avatar
If you would have researched this project prior to starting this you would have noticed you will have to either A.) notch the inner fender lining out to accomodate the larger hinge or B.) remove inner fender lining totally
The hinge is much larger so it sticks out into the inside of the fender.
Not trying to be an ass but try and notch it out as close as u can get.
There wont be that much debri/ water that will get in there.
ppl with body kits dont run inner fender lingings bc tey dont match up to the aftermarket kit
Old Dec 5, 2011 | 08:09 PM
PsychoCam's Avatar
is it hitting the fender itself? does it fit fine with out the fender liner?
nutty21's Avatar
Well I already removed the finder lining and cut the hinge.
It still don't fit, so now what?
Old Dec 5, 2011 | 08:10 PM
nutty21's Avatar
No it's hitting the hinge with out the liner.
Old Dec 5, 2011 | 10:13 PM
nutty21's Avatar
Old Dec 5, 2011 | 10:17 PM
pics would do this thread wonders
Old Dec 5, 2011 | 10:25 PM
scagnetti76's Avatar
You could try Pm'ing Beamer. He is the only one i know of who has or had lambo doors.
Old Dec 5, 2011 | 10:26 PM
nutty21's Avatar
If you have a cobalt then you have pics. The rocker guard has a lambo door hinge behind it that you can't see, do to the fact that its behind it, so it won't set in place exactly so it will built up properly.
I looks like a Cobalt with a rocker guard that wit properly.
Looking for someone that has installed Vertical Door hinges here to find out what exactly they did when they did theirs.
Old Dec 5, 2011 | 10:28 PM
nutty21's Avatar
Thanks,
Now there's some more useful info.
Old Dec 5, 2011 | 10:31 PM
Np, hope he can help ya out. GL with your project.
Old Dec 5, 2011 | 10:32 PM
sponge14's Avatar
Old Dec 5, 2011 | 10:35 PM
TommyP's Avatar
AWD > FWD
wtf is a rock guard?
Old Dec 5, 2011 | 10:41 PM
nutty21's Avatar
