Here is all the info you need for the head impact recall.
Old Mar 26, 2007 | 09:02 PM
n8dogg's Avatar
Subject: Customer Satisfaction - Modification to Increase Head Impact Protection #06221 - (03/14/2007)
Models: 2005-2006 Chevrolet Cobalt Coupe
2006 Pontiac Pursuit Coupe
Without Roof-Mounted Side Impact Airbags
Condition
GM recently improved the head impact protection in certain 2007 model year vehicles. This added protection will reduce the risk of injury if a front seat occupant’s head were to impact a point near the attachment of the sun visor to the roof. GM is making similar changes to certain 2005-2006 Chevrolet Cobalt Coupe and 2006 Pontiac Pursuit Coupe vehicles that were built before these changes were implemented.
Correction
Dealers are to install an energy-absorbing device between the front headliner and the vehicle roof.
Vehicles Involved
Involved are certain 2005-2006 Chevrolet Cobalt Coupe and 2006 Pontiac Pursuit Coupe vehicles not equipped with optional roof-mounted side impact airbags and built within these VIN breakpoints:
Year
Division
Model
From
Through
2005
Chevrolet
Cobalt Coupe
57503302
57673449
2006
Chevrolet
Cobalt Coupe
67600139
67832359
2006
Pontiac
Pursuit Coupe
67600110
67832286
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS. Not all vehicles within the above breakpoints may be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided through GMinfoNet Recall Reports. Dealers will not have a report available if they have no involved vehicles currently assigned.
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
Parts required to complete this program are to be obtained from General Motors Service and Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
Part Number
Description
Qty/ Vehicle
25844441
Absorber, Hdlng T/Pnl Engy Frt
NPN Obtain Locally
Adhesive Sticks, Hot Melt
Service Procedure
Tools Required
Hot Glue Gun
Important: Install the energy absorbing (EA) plastic piece into the headliner at both the driver and passenger side A-pillar locations.
1. Remove the A-pillar trim panels. Refer to Windshield Garnish Molding Replacement in SI.
2. Remove the sunshades from the vehicle. Refer to Sunshade Replacement in SI.
3. Remove the assist handle from the vehicle, if equipped. Refer to Assist Handle Replacement in SI.
4. Remove the sunroof finishing lace, if equipped. Refer to Sunroof Finishing Lace Replacement in SI.
Object Number: 1883691 Size: SH
Click here for detailed picture of above image.
Important: The headliner will drop about 203 mm (8 in), which will provide adequate room to install the insert energy absorbing (EA) plastic piece into the headliner. Use hot melt adhesive sticks to glue the EA plastic piece into the headliner.
5. Locate the installation anchor points (2) for installing the energy absorbing (EA) plastic piece (3) onto the headliner (1).
Object Number: 1883692 Size: SH
6. Apply hot glue to the energy absorbing (EA) plastic piece.
Object Number: 1883693 Size: SH
Important: Ensure that the energy absorbing (EA) plastic piece is installed properly. The tail ends of the energy absorbing (EA) plastic piece (2) should wrap around the anchor posts (1) of the headliner material. The body of the EA plastic piece should be firmly attached to the headliner.
7. Insert the energy absorbing (EA) plastic piece to the headliner trim with hot glue.
8. Tuck headliner in place to ensure proper fit with the A-pillar trim panels and sunshades.
9. Install the A-pillar trim panels. Refer to Windshield Garnish Molding Replacement in SI.
10. Install the sunshades. Refer to Sunshade Replacement in SI.
11. Install the assist handle from the vehicle, if equipped. Refer to Assist Handle Replacement in SI.
12. Install the sunroof finishing lace, if equipped. Refer to Sunroof Finishing Lace Replacement in SI.
Courtesy Transportation
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product program is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
Claim Information
Submit a Product Recall Claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labor Op
Labor Hours
Net Item
Install Energy Absorbing Device
MA-96
V1557
0.7
Add: Remove Assist Handle and/or Sunroof Finishing Lace
0.1
Courtesy Transportation for vehicles within the New Vehicle Limited Warranty
MA-96
* The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up for the energy absorbing devices needed to complete the repair.
** The amount identified in the "Net Item" column should represent the actual sum total of the current GMSPO Dealer net price plus applicable Mark-Up for actual amount of glue stick needed to perform the required repairs, not to exceed $3.41.
*** Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual for vehicles within the New Vehicle Limited Warranty.
**** The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
Refer to the General Motors WINS Claims Processing Manual for details on Product Recall Claim Submission.
Customer Notification
General Motors will notify customers of this program on their vehicle (see copy of customer letter included with this bulletin).
Dealer Program Responsibility
All unsold new vehicles in dealers' possession and subject to this program must be held and inspected/repaired per the service procedure of this program bulletin before customers take possession of these vehicles.
Dealers are to service all vehicles subject to this program at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Program follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this program enters your vehicle inventory, or is in your dealership for service in the future, you must take the steps necessary to be sure the program correction has been made before selling or releasing the vehicle.
March 2007
Dear General Motors Customer:
This notice is sent to inform you that General Motors is conducting a customer satisfaction program that affects certain 2005 and 2006 model year Chevrolet Cobalt Coupe and 2006 model year Pontiac Pursuit Coupe vehicles without optional roof-mounted side impact airbags.
GM recently improved the head impact protection to certain 2007 model year vehicles. This added protection will reduce the risk of injury if a front seat occupant’s head were to impact a point near the attachment of the sun visor to the roof. Since your vehicle was built before these changes were available, your GM dealer will make similar changes to your 2005 or 2006 Chevrolet Cobalt Coupe or 2006 model year Pontiac Pursuit Coupe.
Your GM dealer will install an energy-absorbing device between the front headliner and the vehicle roof. This service will be performed for you at no charge .
To limit any possible inconvenience, we recommend that you contact your General Motors dealer as soon as possible to schedule an appointment for this repair. By scheduling an appointment, your dealer can ensure that the necessary parts will be available on your scheduled appointment date.
You may be contacted by a dealer other than the dealer who sold or is currently servicing your vehicle. Please be advised that you may take your vehicle to the General Motors dealership of your choice to have the recall service work completed.
This letter identifies your vehicle. Presentation of this letter to your dealer will assist their Service personnel in completing the necessary correction to your vehicle in the shortest possible time.
We are sorry to cause you this inconvenience; however, we have taken this action in the interest of your continued satisfaction with our products.
Customer Support Department
General Motors of Canada Limited
06221
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old Mar 27, 2007 | 08:43 AM
fr33k's Avatar
That's the same as the 06217 camp except they added more vin numbers and the Pontiacs
Old Mar 27, 2007 | 09:19 AM
05REDROCKET's Avatar
Just kidding...
But does anybody have this done yet I would love a pic?
Old Mar 27, 2007 | 09:25 AM
fr33k's Avatar
Mines on order for my yellow balt. When it gets here I'll take some pics of everything so we can see what's goin on. On another thread, someone posted the actual pics the techs sees when they look up this campaign.
https://www.cobaltss.net/forums/general-cobalt-68/update-recall-06217-%2A%2Aphotos%2A%2A-50724/
It's the 06217 campaign but it's identical as this 06221 one.
Old Mar 27, 2007 | 11:24 AM
celicacobalt's Avatar
doesnt seem like something id wanna have done even though i got the notice i dont like them tearing my car apart
Old Mar 27, 2007 | 12:45 PM
iLLmaTic3s's Avatar
yeah seriously. they are gonna be taking the whole car apart. how long shud this install take?
Old Mar 27, 2007 | 02:05 PM
fr33k's Avatar
They just lower the front corners of your headliner and hotglue a piece of energy absorbing plastic to the inside of it. Then put the corner of your headliner back up. The pic on the other post shows the headliner pretty far down on the vehicle but all ya need is enough room to place that piece of plastic.
Old Mar 27, 2007 | 02:23 PM
with my gauges in the pillar im afriad they would screw somthing up with them.
Old Mar 27, 2007 | 02:59 PM
JohnnySasakiMGS's Avatar
Well. I guess I'll be helping them out with this one. I don't want them messing up my custom headliner.
Old Mar 27, 2007 | 03:19 PM
Red06LS's Avatar
Ok Fk that, its not even worth it. My hat will give me more head protection that that little piece of ****. And didnt they say its for if you roll w/o your seat belt on. i always use my belt so im not too worried about getting this done.
Old Mar 27, 2007 | 03:24 PM
BLKSS's Avatar
I got the notice in the mail yesterday. Im sure GM has a good reason for this. Why else would they waste their money? I will call my dealership to set up an appointment this week.
Old Mar 27, 2007 | 06:18 PM
XM15's Avatar
I got my letter yesterday. I guess I'll set up an appointment for next week or something.
ineedacobaltss
Nov 7, 2015 02:25 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 28, 2015 12:51 PM
