Higher flow intercooler pump?
Anyone with supercharger setup ever try a higher flow pump? If so which one and was there a performance gain?
07blackg5 ran two stock pumps before.
I know the ZL1/Z06 pumps are brushless and flow much more but also cost like $4-600. |
ive been running a meziere 20 gpm pump for a lot of years now, i cant even remember when i put it on. i put it on when i did dual pass/opt b so its hard for me to say how much it does over a stock pump. its been reliable though, never given me an issue.
You have any idea what the flowrate of the stock pump is for comparison?
Originally Posted by jdbaugh1
(Post 7707189)
Intercooler pump flow testing results - Lingenfelter Performance Engineering Forum |
Originally Posted by steelmesh
(Post 7707192)
You should find this very compelling:
Intercooler pump flow testing results - Lingenfelter Performance Engineering Forum It looks like the OEM ZR1 intercooler pump may be a good option as I'm not sure what restriction my system yields. The OEM ZR1 pump seems robust against any anticipated restriction while still maintaining good flow. |
(Post 7707193)
Thanks for sharing. Is the "CTSV Bosc" pump the same one that is OEM in the LSJ?
Lingenfelter post says it's a: BOS0392-022-002 ZZP LSJ pump has part number: 0392022002 Is the ZZP pump not the factory replacement pump, or is it 'upgraded'? Opps I've always thought they were one and the same if I am wrong. |
(Post 7707194)
Sure as heck looks like the LSJ pump on the outside and found this info:
Lingenfelter post says it's a: BOS0392-022-002 ZZP LSJ pump has part number: 0392022002 Is the ZZP pump not the factory replacement pump, or is it 'upgraded'? Opps I've always thought they were one in the same if I am wrong. |
