kcpoloman build thread
Swapped spark plugs and transmission oil today. Took the front wheels off while i had it up to clean them. Letting them dry over night and then plasti dip them tomorrow.
So I was going to change my fuel filter. I attempted to start the car so I could pull the pump fuse to relieve pressure from the lines. However the car wont turn over. The car ran when I got it. The starter turns over just fine but Im not getting it to start. Im not hearing any fuel pump however.
I also have the seats out of the car. I noticed theres what I assume airbag type sensor plug that goes into the bottom of the drivers seat. Could that prevent the car from starting? Some kind of safety feature?
kcpoloman (04-27-2017)
#40
Did undercoating yesterday and reinstalled the interior after painting the carpet with color bond. Need to do some sanding but almost ready to start painting the car with the plasti dip.
kcpoloman (05-06-2017)
#44
Really great progress you got going on! Looks nice! How was the underside before you gave it the undercoating? What did you use for it? I need to do that to mine. I'm enjoying the transformation!
kcpoloman (05-08-2017)
#45
Underside was good. No rust anywhere. I used simple green and paper towels then water and paper towels to get it all off. Let it dry then hit it with 3M undercoating. Took about six cans.
kcpoloman (05-09-2017)
#48
You would need to literally submerge the filter to cause hydro lock.
The injen intake sits up high enough to avoid that. Any potential rain water that hits the filter will evaporate after reaching the blower.
Nice work though, I enjoyed looking at the restoring photos.
#49
You will be ok with the hydro shield....
#50
Not sure about noise but the 3M undercoating I used wasnt cheap. I noticed its much more like a truck liner than the cheaper brands of undercoating that really just appear to be a flat black paint. I havent really bothered touching it but you can tell from the picture its pretty textured.
