Lil Blacky’s official TVS build thread(long post)
Old 01-13-2018, 05:05 PM
  #201
jdbaugh1's Avatar
Though I have done it, hours on interstate doing 85 with the windows rolled down kind of sucks. I won't delete my AC until I gut the interior and go full race car. It just gets too damn humid here. I don't mind dry heat at all and windows work then. However moving air doesn't cool your body very well when it is so damn humid your sweat won't evaporate. The AC compressor is essentially just an idler pulley when it isn't turned on anyway.
07MetallicSC (01-13-2018)
Old 01-13-2018, 09:10 PM
  #202
chevygirl2006's Avatar
Old 01-13-2018, 09:37 PM
  #203
Henry3959's Avatar
Clean that GM heat exchanger out.
It looks like it doing a better job blocking air flow than anything else.
Old 01-13-2018, 09:39 PM
  #204
CLEan it out?
Old 01-13-2018, 09:40 PM
  #205
I’m putting a newer looking one on it. I have an extra
Old 01-13-2018, 09:42 PM
  #206
Henry3959's Avatar
Remove it and pressure wash it from the back side with a good engine degreaser. It looks like it has a lot of debris in it.
Old 01-13-2018, 09:43 PM
  #207
Henry3959's Avatar
Did you go with a dual fan shroud? Finished mine today and both fans operate just like the SS.
Old 01-14-2018, 10:00 AM
  #208
Yes. I bought one but it’s not here yet
Old 01-15-2018, 11:44 AM
  #209
Lsj dual fans are in
Old 01-15-2018, 11:45 AM
  #210
Also swapped to lsj ac lines
Old 01-15-2018, 11:50 AM
  #211
Henry3959's Avatar
What's different about the LSJ AC lines?
Old 01-18-2018, 10:36 PM
  #212
Henry3959's Avatar
Was just looking at some of your pics... did you replace any of the timing chain / gear components?
The chain looks like it is very stretched and the gear teeth are sharp. That chain should be riding that gear down the whole side.
Old 01-19-2018, 06:35 AM
  #213
jdbaugh1's Avatar
It's possible her tensioner wasn't activated yet.
Old 01-19-2018, 07:24 AM
  #214
It wasn’t activated yet and it’s a brand new chain
Old 01-19-2018, 07:41 AM
  #215
Oh and the lsj ac line has different bends and fits better up front. It’s no longer pushed up against my fans like the 2.4 one was
Old 01-19-2018, 07:44 AM
  #216
This thing. Lsj lines are under my manifold now
Old 01-19-2018, 09:07 AM
  #217
Henry3959's Avatar
I like that fit much better!
Is it a perfect fit?
Old 01-19-2018, 10:52 AM
  #218
yup goes right on
Old 01-20-2018, 02:35 PM
  #219
Henry3959's Avatar
I know the whole nine yards is damn expensive OEM but those teeth look sharp. Mine have 123,000 NA mild miles on them and are all pointed. No way could I put new parts on old parts. If I didn't have GM warehouse connections I don't know if I would have gone 100% OEM. I got every component GM OEM including Cam Gears and OEM Balance shaft set for $380.64. Crate engine Warehouse gets $625.00 for what I purchased. That made it easy to afford all ARP bolts to go with it
Timing chain set
LE5 2.4 Timing Chain Deluxe Set LE5DTCKIT
Balance chain set
L61L35bck Balance Shaft Chain Kit for 2.2 and 2.4 Ecotec Engines
Old 01-20-2018, 05:29 PM
  #220
My balance shaft chain and timing chain is new. The only thing used are the cam gears.
  #221
And the tensioner wasn’t even in yet in that picture.
Old 01-21-2018, 12:37 AM
  #222
Henry3959's Avatar
If I hadn't received mine for $75 for the pair I would have purchased a set from ZZP. Mine are just too worn.
Old 01-21-2018, 06:50 AM
  #223
jdbaugh1's Avatar
I replaced my timing gears near 100,000 miles with the timing chain but honestly they didn't look worn at all. Hard to tell the difference from the new units. I use M1 and don't have VVT though, don't know how that affects it.
Old 01-23-2018, 08:18 PM
  #224
Henry3959's Avatar
Are you running the Phenolic spacer between your head and intake? I'm thinking about it but with an Auto my SC is already right against the front end.
Old 01-23-2018, 09:21 PM
  #225
Yes I am. Had to cut a big section of metal out to clear the pulley.
Quick Reply: Lil Blacky’s official TVS build thread(long post)
