Lil Blacky’s official TVS build thread(long post)
#352
Could the vibration be from something else. I thought the video sounded very noisy. All I hear is my supercharger.
#353
I spin to 8k too just saying anything over 7,500 they say you need to do something with BS either delete or neutral. I'd look into the vibration more to and make sure what it is because the only difference I notice before and after was I could feel vibes in the steering wheel at idle. Under acceleration I noticed no difference at all. You can't even notice any differences from in-cab videos on mine.
Though I supposed the vibrations COULD be strictly from your BS delete and the effect is just amplified because of your motor mounts. I only have a rotated front mount and it is 1-piece rubber bushing non-voided. Running stock upper mount.
#355
Mine does also and I would like to get a ZZP adjuster so I can go to a 2.6 pulley. I put a new idler / bearing on but the OEM's have a lot of movement.
#357
I'm not going to hit the boost you will but went with .020 / .020 / .018 out of the box. with a .005 piston to wall. I barely had to touch the second rings. First started at .014. That would have been a disaster.
#371
I’m running a 2.7 and the ati so it’s the same as a 2.6. I’ve only seen 23 so far but I haven’t did a full pull. Haven’t even went to redline. So it probably go to 24-25
