Lil Blacky’s official TVS build thread(long post)
jdbaugh1 (02-19-2018)
07blackg5 (02-19-2018)
zeeky420 (02-25-2018)
#385
You mean it's picking up a similar frequency noise? The PCM filters out frequencies that are not the same as a knock frequency but I have seen them pick up other rattles.
Looks like you had some fun colorizing...
#387
Yes it’s showing knock that is not real. Aka false knock. My car is a vibrating machine. Ss strut caps aren’t made anymore by the company that made them. Headlight covers are made by Juan Lopez. His company is velocity aerowerks
#388
There are a few uk builds which are suffering from this continuous knock issue despite what ignition setting are and what fuel we use and what ever the iat are
This is on a 1900 harrop and on 1320 harrop
So if you find the reason for it we would be very intrested in why
#389
My junk ECU picks up false knock continuously and sensitivity can't be adjusted as far as we know (2006 L61 ECU). It's so bad that I have to leave my knock sensor unplugged to make any power. Only knock sensor I have is my eardrums. Not ideal I know but neither is pulling all my ignition timing.
#390
I can desensitize mine and you can set it to where even though it’s knocking it doesn’t pull any timing out. That’s how mine is right now until we turn the sensor down. I wasn’t having false knock until I put aftermarket mounts in the car. And no matter how much timing we take out and how much we adjust afr, it shows the same amount of knock in the same exact place. It will spike and decay/taper down. That’s how we know it’s not real
#398
How? And even if it’s overkill it’s better than cheaping out on a build and have **** break. Geez if people are cheap asses they get ****. If people spend money to do things right and make sure it’s good to go they also get ****. Can’t win. And I have a reason for getting this.
Henry3959 (02-26-2018)
The following 2 users liked this post by 07blackg5:
Slowbalt2000 (02-26-2018),
user 72239 (02-26-2018)
