Lil Blacky’s official TVS build thread(long post)
#58
I don't know what they used on hers but when I deglazed my cylinder walls with a dingle ball hone I asked around a lot from any source I could find and arrived at 320 grit for my 8600XX piston rings with a stainless steel top ring and cast iron second ring. It was hard finding a clear answer. But in the case here and with yours idk what grit would be ideal for your totalseal rings. On their tech page it says grit selection is tricky with different materials and configurations and to just give them a call at 800-874-2753 to let them know about your setup and they will make a recommendation.
#59
I have the specs for the Total Seal Rings that I am using. I just thought the cross hatch in the pics looked very flat.
http://www.totalseal.com/pdf/Install...heet2010_2.pdf
#62
I'm sure it's fine as you had the cylinders very slightly over-bored with slightly oversize pistons right? What I'm getting at is they didn't free-hand this and most likely had it in a proper boring machine that they have precise control over the rate of rotation and reciprocation.
#74
Found out that it wasn’t even really honed. It was deglazed....so we have to take it back and the specs are 220 grit. Glad y’all said something. After y’all did I started asking questions because I don’t want my brand new motor having problems.
#75
I was going to say it shouldn't have been stone honed but didn't want to ruffle any feathers. You don't stone hone a worn, tapered cylinder. You're good up to .007" clearance for a boosted cylinder. If your installing new rings with those used pistons all you want to do is de-glaze it.
