Lil Blacky’s official TVS build thread(long post)
#201
Though I have done it, hours on interstate doing 85 with the windows rolled down kind of sucks. I won't delete my AC until I gut the interior and go full race car. It just gets too damn humid here. I don't mind dry heat at all and windows work then. However moving air doesn't cool your body very well when it is so damn humid your sweat won't evaporate. The AC compressor is essentially just an idler pulley when it isn't turned on anyway.
07MetallicSC (01-13-2018)
#208
Was just looking at some of your pics... did you replace any of the timing chain / gear components?
The chain looks like it is very stretched and the gear teeth are sharp. That chain should be riding that gear down the whole side.
#219
I know the whole nine yards is damn expensive OEM but those teeth look sharp. Mine have 123,000 NA mild miles on them and are all pointed. No way could I put new parts on old parts. If I didn't have GM warehouse connections I don't know if I would have gone 100% OEM. I got every component GM OEM including Cam Gears and OEM Balance shaft set for $380.64. Crate engine Warehouse gets $625.00 for what I purchased. That made it easy to afford all ARP bolts to go with it
Timing chain set
LE5 2.4 Timing Chain Deluxe Set LE5DTCKIT
Balance chain set
L61L35bck Balance Shaft Chain Kit for 2.2 and 2.4 Ecotec Engines
Timing chain set
Balance chain set
#222
#225
