The oil % thingy.
Old Feb 28, 2008 | 09:36 PM
VibrantCOBALT's Avatar
The oil % thingy.
Is the cobalt dash oil % running 5,000 miles?
Old Feb 28, 2008 | 09:39 PM
BLKblurr06's Avatar
I dont really think that it goes by miles alone, but according to how you drive, operating temps, ect.
Old Feb 28, 2008 | 09:40 PM
mkulrey13's Avatar
no, it runs till your oil needs changing... could be 1000 could be 8k all depends on how you drive and how dirty your oil gets.
cause it seems like ive ran my car 3.000 miles and its at 52% still
Old Feb 28, 2008 | 09:41 PM
XM15's Avatar
Yup. If you like to tear around town it will go down faster.
Old Feb 28, 2008 | 09:49 PM
LopsidedJester's Avatar
I've heard the amount of percentage gone depends on the engine rpms, if you run at rpms higher then a certain point then it goes down about 3 times as fast than it would at cruising or idle rpms.
Old Feb 28, 2008 | 09:51 PM
Deersniper17's Avatar
it also takes into account ur oil viscosity and all that stuff...and the heat cycles ur oil is exposed too.
so should i follow that, or still get it changed every 3,500
Old Feb 28, 2008 | 10:09 PM
Omnigear's Avatar
why change it at 3500? i change all my cars at 5000.
Old Feb 28, 2008 | 10:12 PM
rallyracer's Avatar
I dont pay attention to that damn % thingy...I usuall change my oil at around 4000+miles in the winter and around 3000 in the summer.
Old Feb 28, 2008 | 10:24 PM
GULLABLE0NE's Avatar
i change it every 3,000 miles. i always intend to do it at 2,500 but i don't get around to it till about 3,000. at 3000 my meter says about 50% i personally wouldnt let it get any lower than that. if you wait 5 or 6000 miles your oil is probably filthy and your risking damage to your motor
braineater's Avatar
personally i think its just on a mileage thing, i changed my oil 500 miles ago but forgot to reset the gadge, now it says its at 17% witch is obviously wrong.
Old Feb 28, 2008 | 11:37 PM
GhostFox's Avatar
According to my dealership, and you know how they try and get you to come if far more often then necessary, one cobalt came in for an oil change after 1 year with his oil gauge still around 20%. When they dumped the oil apparently it still looked like it had some life in it.
What they told me was wait till it hits 25%, then make an appointment for within the next month.
Old Feb 28, 2008 | 11:40 PM
spree0708's Avatar
ive always changed mine every 2500-3000... you might not have to change it til later but why let your oil get as bad as it can before you change it? simple maintenance like that will improve the life of any car and it doesnt take much time or money for what its worth.
Old Feb 29, 2008 | 12:22 AM
chris88z24's Avatar
bullshit. Synthetic oil actually protects the engine BETTER when it gets dirty!
Old Feb 29, 2008 | 12:31 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I use AMSOIL... I beat the hell out of my car... and it takes A LOT of miles for my % to come down. I think the last one took 10,000 miles. It looked like it still had life in it when I drained it too.
AMSOIL says or guarantees their oil can last like 15,000 miles or a year (which ever comes first) in a Turbo/supercharged car... I'm not gonna wait that long... but hey... they're the experts.
Old Feb 29, 2008 | 10:56 AM
I fell if you're running high grade synthetic you don't have any reason to really change it before 5000 miles unless you're actually racing your car on a track. I do mine about every 5000 miles with mobil 1 and thats about 70% of the oil life meter, if i had amsoil which i'm looking to switch over to i'd probably change to 8000 miles (that **** is amazing). There are certain amount of benefit from having some deposits in your oil rather than running new oil constantly.
Old Feb 29, 2008 | 03:00 PM
rallyracer's Avatar
My car gets pushed to its limits thought-out the warmer months, that’s why I change it around 3000-3500. In the colder month I may push it to around 5000 max.
Old Feb 29, 2008 | 03:01 PM
SilvrLT's Avatar
Well I think the owners manuel states 5,000mi per oil change
Old Feb 29, 2008 | 03:03 PM
scottyguy401's Avatar
I just changed my oil yesterday, and the % thingy was at 53%. But I change my oil every 3 months, and that's about how long I've had the car.
Also, I ended up buying the wrong oil, 10w 30 instead of 5w 30, will this affect my car in any way?
Old Feb 29, 2008 | 03:05 PM
REIGN SS's Avatar
Original Hayden Fanatic
I run mine down to about 20% or so, which is usually around 6500-7000 miles... and that is with Conventional oil...
steddy2112's Avatar
YES
The oil passages are very narrow...go get the right oil
Old Feb 29, 2008 | 03:13 PM
Blue_Balt's Avatar
I find it hilarious that from 100% to around 63% it drops at an higher rate and then all of sudden creeps down.
Old Feb 29, 2008 | 03:16 PM
GhostX's Avatar
You know, I think I bought 10w30 today, whoops. Only my 2nd oil change though,. I'll have to switch mine tonight. Good thing I didn't put it in yet...
Old Feb 29, 2008 | 03:33 PM
Onyxd04Redline's Avatar
If youre using a good synthetic.. ie.. NOT Mobil 1. 5K miles is fine.
