Please help...need tach wire color behind cluster...
I'm in the middle of installing an Ecliptech progressive shift light but am not sure which of the wires going into the cluster is the correct tach wire. I've heard brown/white, green/white....please if anyone who really knows can tell me, I'd really appreciate it...
I got one of these and I want to install on my Sky. Did you ever figure out how to hook it up?
Originally Posted by kennysabarese
(Post 4486992)
what ignition system do you have? ^ cause I had to buy a tach adapter to intercept the signal. Since the harness runs multiple signals down individual wires.
what ignition system do you have? ^ cause I had to buy an autometer tach adapter to intercept the signal. Since the harness runs multiple signals down individual wires. |
If you were asking me... I have whatever is stock on the Saturn Sky RL Turbo... Bosch
I didn't use any tach adapter...stock SS/TC ignition...if I get a chance to get under the insulation, I'll check the color of the wire...
which engine? if you have the l61 or lsj (maybe the le5 i'm not sure) I can tell you when i get home.
I think he's LNF. I am LNF on my Sky
I just looked. Each cylinder has black brown and pink. then the two other sensors going into the valve cover have pink as well as the the intake tube also has pink. Can you check your setup? I just had someone look this up for me and they think it's exactly the opposite. "There are 4 wires to each coil one is black (ground) and the other is pink/black which goes to Fuse 45 (15 amp). Next, there are brown wires common to #1 & 3, and brown/white common to #2 & 4. The brown goes to pin 78 on the ecu which is "LOW REF", and the brn/wht goes to pin 13 which is another "LOW REF". The remaining unique colored wires to each coil are the IC (ignition coil) signal from the ecu. One of THESE should be the tach signal that is needed." |
(Post 4487087)
it isnt green?
You ever find out which wire you used?
Originally Posted by YelloEye
(Post 4883227)
Yeah it's easy. Each cylinder has 4 wires. 3 of them are the same color on all 4 cylinders. 1 of them is different on each cylinder. The different one has the tacho signal.
See the install procedure here. http://www.kappaperformance.com/index.php?topic=3417.0 |
