Rear spring damper fix - Cobalt SS Network
Thread Tools Search this Thread
Old 06-11-2018, 10:37 AM   #1
I'm not sure of the name of this thing...i call it a rear spring damper - GM wants $105 for one.
Can anyone suggest a material I can use to fix the broken foam piece ? The basic plastic is perfect, but the foamy piece above it is worn away on both drive and passenger sides. I'd like to just make something that works. Has anyone ever done this before?
Rude looking, but it should dampen sound around the rear springs.
So the name is the 'upper spring seat - jounce bumper'.
OhSixBalt is offline   Reply With Quote
Old 06-11-2018, 11:15 AM   #2
If I don't hear a suggestion, I'll try fabricating one out a piece of tire, and let the rubber from the tire do the job of dampening - pics to follow.
Old 06-11-2018, 12:08 PM   #3
tire rubber is to high of a durometer for that job. Get a medium to soft rubber to make it
ECaulk is offline   Reply With Quote
The Following User Says Thank You to ECaulk For This Useful Post:
OhSixBalt (06-11-2018)
Old 06-11-2018, 12:17 PM   #4
Ok thank you ECaulk I guess if the durometer is too high then it won't cushion enough. I'll give it some thought and look around town and eBay.
Old 06-11-2018, 01:37 PM   #5
I think dorman? or some aftermarket company resells these much cheaper than the GM part.
Slowbalt2000 is offline   Reply With Quote
Old 06-11-2018, 08:51 PM   #6
Can you use the Spring Insulator here: $11. I used them for my 2009 TC.
Cobalt Springs and Components
Northindy is offline   Reply With Quote
The Following User Says Thank You to Northindy For This Useful Post:
Old 06-11-2018, 09:28 PM   #7
Ok I've placed the order. Thanks.
Old 06-11-2018, 10:13 PM   #8
I also got the CED ones. Worked good.
cluelessk is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Rear Damper Adjustment for KSport Coilovers? 91RS Suspension 21 03-07-2015 10:10 PM
Timing Chain Tensioner - Quick Fix vs Normal Fix Drunkship 2.0L LSJ Performance Tech 1 05-18-2013 12:06 PM
Spring Cleaning!!/Dejon Intake and Spring 80vetteL82 Pictures & Videos 4 03-26-2009 07:51 PM
Lowering spring, spring rates! 06black Suspension 7 03-24-2008 01:02 PM
rear passenger side suspension making noise after eibachs, tried to fix, no luck! CobaltCpe South Central 19 09-25-2007 01:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
