remote start question
hiya, i was just wondering if i got a remote start for my 2.2 cobalt.. could i get it taken off when i get my SS/SC and put it in there? i read that you could put a remote start on a manual but i dont know how. thanks guys.
Originally Posted by VeNoM0713
(Post 708867)
I would highly recommend against this idea. First, you are making more work for yourself in time and money. Second, while you CAN put a remote start on a manual, you shouldn't. Doing it, as said above, required a clutch switch bypass, which is there for a reason. The first time you park the car in gear and use the remote start, you break stuff.
alright.. well i guess i wont get remote start put on my 2.2..but what do you mean it will break stuff i wanted to put it on the SS/SC? wont it come with a warranty? when i get my SS i am planning on keeping it and i hate NY weather.. has anyone put remote start on theyre manual?
(Post 711043)
for a manual couldnt u just put a brick on the clutch? :)
You are going to have problems because you are starting the engine with the clutch engaged. The trans isn't designed to function that way, and the starter will have an extra load on it. And the first time you park the car in gear and forget about that and try to remote start it, the car is going to move and you aren't going to be there.
It's actually illegal to put a remote start on a manual, but I've heard of it being done. And you definitely won't find any legitimate manufacturer make a kit for a manual. It would probably be a huge hassle as other people said because you have to bypass the sensor that tells the car the clutch is in.
(Post 711043)
Check out http://www.compustar.org/2WFMR.htm
They are the only remote start manufacture that makes a remote start that is compatible with a manual transmission. There is no reason a remote start will hurt the car. I've had one on my Red Line for over a year and have had no problems what so ever. Since it is designed to work with a manual trans, you don't have to worry about starting the car in gear. In order for the remote start to work, when you go to park you have to take your foot off the break, put the car in neutral, pull the parking break, and turn the key off. The car will stay running until you get out and shut the door. Once you shut the door the car turns off and the doors lock. |
