Rear spring damper fix
Old 06-11-2018, 10:37 AM
OhSixBalt's Avatar
I'm not sure of the name of this thing...i call it a rear spring damper - GM wants $105 for one.
Can anyone suggest a material I can use to fix the broken foam piece ? The basic plastic is perfect, but the foamy piece above it is worn away on both drive and passenger sides. I'd like to just make something that works. Has anyone ever done this before?
Rude looking, but it should dampen sound around the rear springs.
So the name is the 'upper spring seat - jounce bumper'.
Old 06-11-2018, 11:15 AM
OhSixBalt's Avatar
If I don't hear a suggestion, I'll try fabricating one out a piece of tire, and let the rubber from the tire do the job of dampening - pics to follow.
Old 06-11-2018, 12:08 PM
tire rubber is to high of a durometer for that job. Get a medium to soft rubber to make it
OhSixBalt (06-11-2018)
Old 06-11-2018, 12:17 PM
OhSixBalt's Avatar
Ok thank you ECaulk I guess if the durometer is too high then it won't cushion enough. I'll give it some thought and look around town and eBay.
Old 06-11-2018, 01:37 PM
I think dorman? or some aftermarket company resells these much cheaper than the GM part.
Old 06-11-2018, 08:51 PM
Northindy's Avatar
Can you use the Spring Insulator here: $11. I used them for my 2009 TC.
Cobalt Springs and Components
Old 06-11-2018, 09:28 PM
OhSixBalt's Avatar
Ok I've placed the order. Thanks.
Old 06-11-2018, 10:13 PM
cluelessk's Avatar
I also got the CED ones. Worked good.
Platinum_Injected
01-24-2018 09:01 AM
soaxin
10-08-2015 12:46 AM
SaberD
08-31-2011 05:26 PM
tomj77
04-20-2011 07:50 AM
bbbevans89
03-09-2011 10:55 PM
Quick Reply: Rear spring damper fix
