Shaking at low speeds.
When pulling out from a stop or creeping along in traffic. I feel a shaking when on the gas.
Is this a result of the axles being at a angle. I'm on CM/SSC springs. It's worse if there is people in the car or on a hill. Also my car is auto. |
unfortunately most cars do shake a little when lowered, some just at different speed. i know my car started a little shake on my cm springs at about 40 kms/h. its nothing big or violent though. did you just notice it after the spring install? or has it always been there>
Nope started after the spring install. I had Pro Kit before and never had it.
Also the steering wheel shakes at the same time. It's only under 10 mph that i feel it. |
i get the same thing
same here.. try balancing the tires after the springs settle should help helped mine a little bit
They should be settled. I have 2000 miles on the car since installing the springs.
1000 miles on the tires. |
have you balanced them, or bent rim idk the car is lowered so coulda hit some shit ya didnt see
They were balanced when i got the tires.
But if it was a wheel out balance wouldn't it be felt at higher speeds? I only feel it under load at speeds under 10mph. It's really bad moving slow in traffic. The more weight in the car the more i feel it. |
I'm back on stock springs.
No more shake. |
Originally Posted by bbrewbaker
(Post 5871761)
No more shake. Joel |
yeah i've had this since i put on the H&Rs i almost dont notice it anymore
