Wanting to run these tires.
Not sure if these will rub, I think the 235 width will fit, not sure with the height though.
http://www.tirerack.com/tires/tires....e1=yes&place=2 I think these are some Badass tires, I wanna be like the Z06, Ford GT, and Charger SRT-8. http://www.tirerack.com/images/tires...uper_ci2_l.jpg |
I never did like Goodyear Eagles. Too hard. Not good traction either.
Michellin makes a AAA traction rated tire that is super soft (can't remember which one it is). Those are the one's I'll be replacing the stockers with :) You can almost pinch the rubber off of them with your fingertips. |
Originally Posted by Misery5567
(Post 2231981)
(Post 2231981)
Keep in mind, for every gain you make in traction, your lose in lifespan. I generally don't get more than 22-25k from any set of tires, on the SRT-4, or the SRT-8. WIfe 99 Blazer, thats different, its tires last 50-70K. But 220 treadwear rated tires just arent going to last real long.
i run 235 bfg kdw nt's and they don't rub
235's won't rub, i have 245's on right now and there fine.
I am running 245/45's on a 8" wide wheel and they only rub at full lock to the right while braking.
Originally Posted by lsjwannabe
(Post 2237991)
Originally Posted by Inferno
(Post 2237998)
Originally Posted by SS07
(Post 2231927)
http://www.tirerack.com/tires/tires....e1=yes&place=2 I think these are some Badass tires, I wanna be like the Z06, Ford GT, and Charger SRT-8. http://www.tirerack.com/images/tires...uper_ci2_l.jpg Pirelli P-Zero Rosso. Wait - that name sounds familiar... |
Originally Posted by Tomtwtwtw
(Post 2238095)
If you're concerned about who uses what tires, why not use the tire that Ferrari, Lambo, and Porsche use?
(Post 2231981)
Michellin makes a AAA traction rated tire that is super soft (can't remember which one it is). Those are the one's I'll be replacing the stockers with :) You can almost pinch the rubber off of them with your fingertips. if they are that soft then they are not going to last long,let alone be good for a daily driver tire. they maybe good for the track or auto cross but thats too soft for a daily driver like i said. |
(Post 2238054)
Are you on stock springs though? My Eibach Sportlines make my 225/45-18's rub.
yep sure am |
(Post 2241123)
Who cares. The pirellis are crap.
