colodude18 |
08-01-2012 11:26 PM |
First of all, there is no wax that will protect your car for a year. If it's a daily driver, you'll get 3 months tops depending on weather and how many times you wash it. The golden rule applies here: "If it sounds too good to be true, it probably is".
Now about washing: Many ppl underestimate the importance of properly washing a vehicle. This is when most of the swirls and micro marring takes place. Start by power washing if the car is very dirty. If you don't have a power washer, go to the coin car wash and power wash it with soap. DON'T RINSE to prevent water spots and drive home. Now do a 2 bucket wash (one bucket with shampoo, the second one with clean water for rinsing out your wash mitt. Use a wool wash mitt. Use as much soap as you can, but use a car shampoo, nothing like dish soap which will strip off your wax.
Drying is very important as well. To get most of the water of the car, use a method called "sheeting"; disconnect the nozzle from your garden hose and let water run off each panel of your car. You'll be amazed at how little water will be left on the car. Dry using microfiber drying towels. If you cherish your paint you'll get quality stuff, which means don't go to Target or Walmart. A good MF towel is at least 10 bucks. A piece. Good rule of thumb is if it has a label attached, it's no good. Labels are typically sewn on with thread that will scratch your clear coat.
As for products to use, it's a matter of how much you're willing to spend. I use exclusively Adam's products on my car. It's not cheap, but it's incredible quality, and their service is unparalleled in the car care or any other industry. adamspolishes.com They also have tons of instructional videos on their web site from cleaning and washing to polishing and waxing.
