Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   General Cobalt (https://www.cobaltss.net/forums/general-cobalt-68/)
-   -   What Are The Chevy Cobalt Rear Deck Electrical Boxes? (https://www.cobaltss.net/forums/general-cobalt-68/what-chevy-cobalt-rear-deck-electrical-boxes-329134/)
ThePie 06-21-2020 04:35 AM
Hey,
So the other day I was looking at what's under the rear deck and noticed two boxes.
It looks like the purple outlined box below is the Radio Control Unit. Not to sure what the other orange outlined box is though. Any ideas?
https://cimg5.ibsrv.net/gimg/www.cob...cf98ad7c54.jpg
blu3_v1p3r 06-21-2020 04:51 AM
The one in purple is for satellite radio. If you don't have XM it's not needed as far as I know. My base model didn't have that and I had a headunit from an SS unlocked in my car. I don't know what the other one is.
ThePie 06-22-2020 04:23 PM
If those are not used / needed I was going to remove them. No point in keeping unused items around. Guess I'll see what happens when I start unplugging that mystery box outlined in orange...
colodude18 06-22-2020 04:27 PM
Pretty sure the other one is Onstar. If you don't have an active subscription I recommend removing or at least unplugging it. Onstar continues to collect all sorts of data (that it can sell) about your driving habits and location even after you cancel your subscription - yikes.
USMCFieldMP 06-23-2020 02:06 PM
If/when you pull that XM box out, please do me a favor and weigh it. I'm curious if it'll be worth the trouble for me to pull everything apart and remove it.
I don't imagine it'll be much though.
ProfDNS 06-23-2020 05:09 PM
When I was doing my sound deadening, the front box weighs maybe 1.5-2kgs max. The back one I would say is about 1kg.
USMCFieldMP 06-23-2020 05:21 PM
Cool. Totally not worth the savings then. I didn't think they'd weigh much, but you never know.
ProfDNS 06-23-2020 05:52 PM
It's a pain in the ass in get that back cover off, DEFINITELY NOT worth tearing apart for very little weight reduction.
You have to disconnect the battery, take the rear seat out, undo the 4 (very tight) bolts for the seatbelts, pry the back 2 B pillars (these have airbags hence the battery negative disconnect), take the head rests out, unclip the 2 plastic retainers where the back seats go, feed the belts through the openings, then pull (hard).
Otherwise, it's easy :lol:
blu3_v1p3r 06-24-2020 04:29 AM
agreed the rear deck cover is PITA. I had to replace the rear speakers in my base model, I don't remember what all I had to do to get under there, but i managed to undo enough to be able squeeze my hands in there without pulling the whole thing out.
USMCFieldMP 06-24-2020 11:31 AM
I don't have the airbags (2005 didn't get them) and I've always run the car without the rear headrests (no one sits back there, and it increases visibility just a touch).
But yeah, I'll be sure to skip doing that then, lol.
Kolt 06-24-2020 12:29 PM
Purple is the digital radio receiver (XM module) and the orange box is onstar module. If you remove the onstar module you will need to install a jumper because the low speed and high speed communication buss runs through/to it , other option is to just unplug the white and brown connector and leave the black one hooked up. That will leave the communication circuits intact while effectively disabling the module.
colodude18 06-24-2020 01:09 PM
Yup defnitely a pain. I did this 10 years ago but i still remember. I did this on a 100 degree day to boot :lol:
https://cimg2.ibsrv.net/gimg/www.cob...3a1a5bdef2.jpg
https://cimg3.ibsrv.net/gimg/www.cob...141244ab21.jpg
ThePie 07-01-2020 06:05 PM
Yep, removed the two boxs and found out that the orange outlined box is needed to start the vehicle so plugged it back in.
@colodude18 what did you do for the jumper or is there a adapter that you purchased. I want that box gone! lol
ThePie 07-02-2020 11:32 PM
@Kolt
What pins need to be jumped?
Kolt 07-03-2020 12:21 AM
Originally Posted by ThePie69 (Post 7733821)
@Kolt
what year is yours
ThePie 07-03-2020 12:45 AM
Originally Posted by kolt (Post 7733823)
what year is yours
2008 lnf
Kolt 07-03-2020 09:32 AM
1 Attachment(s)
Originally Posted by ThePie69 (Post 7733824)
2008 lnf
Ah, duh its in your sig :lol:
Here is the connector end view for the black connector. You will need to jump pin 2 to pin 8 and pin 3 to pin 9. If your going permanent delete the best thing to do is just cut those wires and solder and weather tight heat shrink them together making sure there is less than 4 in of straight wire (keep them twisted).
ThePie 07-06-2020 01:04 AM
Thanks for that info, I pulled out the OnStar box and since I couldn't find a connector for that factory end and I didn't want to modify it, I ended up taking the OnStar box apart, and then dremel'ing down the connector and soldering the pins together with some spare wire. That ended up being my solution and everything works great! Plus I saved a whopping 3 pounds! Go weight reduction!
I know how much everyone likes pictures on here...
https://cimg7.ibsrv.net/gimg/www.cob...5204bae903.jpg
https://cimg8.ibsrv.net/gimg/www.cob...a7b8f65c41.jpg
https://cimg9.ibsrv.net/gimg/www.cob...37288abd9f.jpg
ProfDNS 07-06-2020 08:26 AM
I need to do this. Although I thought that by installing an aftermarket radio, it would disable the unit as well.
Kolt 07-06-2020 09:25 AM
Sorta? Installing a aftermarket radio makes it where you cant hear anything from the OnStar module because it cant communicate with the radio anymore but its still there. Pulling the fuse or disconnecting the connectors I mentioned will disable it.
