what does this mean?
Not legal for use on catalyst-equipped vehicles except for racing vehicles which may not be operated on a highway. Pre-catalyst vehicles must use original emission control devices. It is the responsibility of the customer to reinstall these devices on the vehicle.
http://www.pacesetterexhaust.com/hea...tail.php#notes |
It said that the cat must be relocated meaning its being altered from manufactureres specs. I know with the pacesetters the stock downpipe must be modified to accomodate the header. Maybe referring to that not sure?
so you need a dp beside stock i presume
it means that its not going to pass emissions inspection.
thank god my car is registard in michigan! they dont have emission inspectoins.
so how can it be 50state legal but not cali?
1. Flanged Collector 2. Slilp-fit Collector 3. Hook-ups for smog & engine management sensors 4. No smog or engine management hook-ups 5. Comes with collector reducer. Fabrication required to hook to exhaust system 6. Comes with header extension to connect to stock system. Fabrication may be required 7. Fits cylinder heads with evenly spaced exhaust ports 8. Fits cylinder heads with paired exhaust ports 9. Catalytic converter must be relocated 10. Fits vehicles with 14-1/2" catalytic converter 11. 50 States legal |
thats a double standard right there. First you said it claims to be for track use only, and now you say it says 50 state legal. sorry but if its for track use only, then its not 50 state legal
the website says both
in the same webpage |
then dont buy it... you cant have both, its one or the other.
