Wish Me Luck (New Clutch Install)
I am about to embark on changing the clutch on my 09 LNF. I just finished up with my Trifecta tune about a month ago and went to pull out of my dentist's office when I felt the clutch slip in WOT in 2nd. I knew this was coming so I saved up to buy everything needed. This will be my 4th clutch done and my 1st in the Cobalt so I feel like I know what's going to happen. Anything else anyone can think of that I may need or advise? I read these clutches suck to bleed properly.
OTTP Stage 2 Clutch
LUK Flywheel
ARP Flywheel bolts
Clutch elbow
Clutch pipe
2 quarts AC Delco 19351859 Gear Oil
Rear Main seal
Bought a torx socket and bit set along with an engine support stand.
OTTP Stage 2 Clutch
LUK Flywheel
ARP Flywheel bolts
Clutch elbow
Clutch pipe
Rear Main seal
ive done a full motor swap, 5 tranny swaps, and a few ecotec clutches. honestly not that hard. if your engine cradle has been out before it wont be as bad. I had a few times where the main engine cradle bolts seize in the cage nut. I recommend kroil. take your time and don't rust. I got good enough I could do a tranny swap in 3 hours by my self with no lift or power tools.
Okay good to know. I recently replaced the control arm bushings with spherical ones so I know those large bolts should come out no problem. The other ones may be a different story.
SChassisMostly (07-19-2018)
I hope they work. I got them since they are reusable and actually cheaper than the stock bolts.
Any tips on doing a rear main seal? Thought I would do it while I was back there. This issue is all the one's I've done have some sort of housing around it you can unbolt to take it off. This one looks like it is completely pressed in.
Well on Saturday I was able to pull the tranny in about 4 hours. I ran into the issue with stripping out 2 of the 3 torx bolts on the TOB but I got them out today. Just to let everyone know, those ARP 209-2801 bolts will work. Got the new clutch in and will need a buddy to get it back in. Hopefully next Saturday I'll have it done.
