2.0 LSJ Engine: Airbox modification
Airbox modification
Recently I spent time adapting a conical air filter to the stock box, left the bottom off and BAM cold air for $35, well here are some pix and DAMN is the S/C loud now, love it!
Talk about turning peoples heads, the car sounds like a mini from Italian Job
Butt dyno says def more power, car is chiping and screetching everywhere now
Enjoy:
Now the fun starts, Basically you need to get your stock airbox our of the car, it is located DS in front of the wheel, you have to remove 2 push pins, and 7-8 7mm screws and then you can bend back the splash guard. Now this must be done after removing the DS front wheel.
Once the splash guard is moved then you go in and remove 3 nuts holding the airbox on and loosen the upper clamp in the engine bay where the intake mates to the TB adaptor pipe.
Disconnect the MAF line(1 electricl connector) and then you take your time removing the box(will take some twists and contortions) you also have to pop 1 harness grommet retainer but this is simple)
Installing and measuring, once it is out and you have the air filter(BTW the filter is a spectre Universal pt number 8138) this filter has adaptor rings to mate it to 3", 3.5" or 4", you will use all adaptors to mate it to the 3.15"stock opening, here is the only real tricky part, you need to put the 3" adaptor on the stock box(the pic below shows the 3" adaptor already on), trim the outer lip off a little since the stock lip is slightly larger than 3" with an xacto knife then the rest of the filter adaptors slide on no problem
Filter with adaptor rings
Installed Filter, you drill one small hole even with the location of the clamp I used a 1/4" bit and a slim flathead to get in there, and with a flash light in the snorkel for light the clamp shows up fine, once tight it is reversal of removal! Enjoy!
(HOLE LOCATION)
Installed Filter 2
Finished and installed back in the car
Installed ! Now the fun can start! Great thing is only mod to the air box was 1 small hole drilled in the funnel for screwdriver access
I have a video with sound but have not had a chance to upload it, tomorrow.. it is loud
EDIT:Aww heck here it is
right click and save as
SS INTAKE VIDEO AVI
Enjoy:
(HOLE LOCATION)
Installed Filter 2
SS INTAKE VIDEO AVI
Last edited by SS_SC_Cobalt; Jul 21, 2005 at 01:09 PM. Reason: Adding more HOW TO info
Universal Specter air filter bought at pep boys and it is clamped in, hense the reason for the 1 small drilled hole, had to get a screwdriver in to tighten the clamp
Well considering all I did was fit a aftermarket filter and clamp it to the stock box, you dont have a lot to worry about except driving thru a foot or more of water
Originally Posted by MarcS
I thought about doing this too, but I'm going to wait until there is a better aftermarket.
I paid a lot of money for a car, so i'm going to be very careful about what I put on her
Originally Posted by phxSS
Hmmmmmm. Put ur car ona dyno, and see how it worked for you. How much better could a typhoon intake be compared to this?
EDIT:Vid is up in the bottom of the original post, rt click and save as ! Just turn your speakers down a bit
Enjoy!
Very clever on the hole in the air box to tighten the filter.
This is totally how to material.
lol sounds kinda funny. Do a video of you actually driving it, so we can get a better idea of how loud it is.
How-to, I'm honored....
Originally Posted by NightmareSS
I second that. I would definatly love to hear ya driving it. Do you have any better detailed instructions for us. Thanks, Erik
Originally Posted by selfinfliction
now we need to figure out a way to make the small splashguard removable... like with some zuess fasnteners or something... so we could drop it out for an actual cai, and put it back on when it is raining
NEW vids from inside the cabin, right click and save as :
SS S/C video 1
SS S/C Video 2
SS S/C Video 3
SS S/C video 1
SS S/C Video 2
SS S/C Video 3
i did the same thing to my ss but i dident have to drill a hole in the air box all i did was remove the rubber from the filter and put it on the air box than i tightend it down with a socket than i just worked the filter back on the rubber it is a little more work but it leaves no hole in the air box i figured if any thing goes wrong i can just put the stock filter back in and the dealer will never know the differance
SS S/C video 1
SS S/C Video 2
SS S/C Video 3
SS S/C video 1
SS S/C Video 2
SS S/C Video 3
I went to advance autoparts and they had crappy APC filters all already opened. Where online can I find the Spectre filter you used?
Also, have you had any CEL's after installing?
Edit: My boost gauge doesnt jump past 10 as quickly as yours does in the video. Did it do that before you installed the filter?
most intakes do very little, but no one realizes it.....
homemade ones like this are more efficient than the holy-crap-its-awesome-INJEN intake
lol, I'm going to do this too. I'm bored and have to do something. Plus, you can't beat that sound the SC makes.
I will admit the car seems to respond a lot faster and as I said before it def has more grunt, she is breaking the tires loose at will now
I honestly think the supercharger lag if you will is lessened!
now if the header and my cat back would come in.....
intake...
I just got my K&N filter (E-1009) install yesterday and WOW! It runs awesome...The blower wines just like your video clips and the car destroys the tires at will now. I left the bottom of the stock airbox out too get the cold air in. I just installed the bottom slash guard back in...Nice performance mod...I am going too put the car on the dyno soon.....
