Interior: hide away buttons for under steering wheel compartment
Old Nov 29, 2012 | 09:49 PM
justin709's Avatar
Things you will need:
*some sheet metal (I used the side of a old computer)
*Tin snips or grinder
*measuring tape
*marker
*drill and bits
First get your metal
and your going to want to cut this out (you can take half a inch off the top)
then bend it 90 degrees
next place your sheet metal above the under steering wheel compartment on the inside and make your marks for your 2 mounting holes, and the area that your buttons can take up.
the style on buttons i used for this are 3/4 round LED switches, i'm sure if your using something different it will be much the same to install. Mark your holes evenly apart make a pilot hole and then drill as large as needed.
clean it up
hit it with some paint and add switches
i used very small screws and nuts that i also paint to mount the bracket
wire up and place back in car
just a small clean easy DIY project i thought i would share with you guys
Old Nov 30, 2012 | 03:38 PM
06cobalt racer's Avatar
very nice man!! now you just have to remember which spring does what since you cant see them.
Old Nov 30, 2012 | 03:50 PM
Wow thats really nice and cool. good work and thanks for sharing
Old Nov 30, 2012 | 03:56 PM
MastaShaKe_88's Avatar
wat are you gonna use the switches for????
Old Nov 30, 2012 | 04:01 PM
damastah's Avatar
buttons for
air bags // nitrous // panty dropper
lol on a serious note... good write up!
Old Nov 30, 2012 | 04:09 PM
Originally Posted by damastah
buttons for
This^^^ or else this was a useless mod
Old Nov 30, 2012 | 04:14 PM
Burninrubber's Avatar
pretty sweet man. I made one that fit in the compartment but found issues with the buttons clearing the trim piece. Back to the drawing board.
Old Nov 30, 2012 | 04:35 PM
z062007vette's Avatar
Nicely done.
Old Nov 30, 2012 | 04:42 PM
mkulrey13's Avatar
Sub'd. Looks awesome!
Old Nov 30, 2012 | 04:56 PM
jzehren11's Avatar
wow thats an awesome idea!!! def. gonna be doing this!!
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
