Interior: Hinow41 led button mod
Old 08-11-2009, 10:44 AM
Grich171's Avatar
so that white piece you see from the top side comes out... in the one switch you can do anything with it from the bottom side because of the black piece for the connector
Old 08-11-2009, 11:14 AM
hinow41's Avatar
Can you take a pic of the bottom for me? Sorry about not knowing 100%. I wish I had myt car and not this stupid rental ><
Old 08-11-2009, 11:44 AM
Grich171's Avatar
this is the best pic i could get...also what did u do with the little blue rubbery thing that goes over it...and then for the steering wheel buttons on the 09 they are those really really small leds theyre like little baby squares..u replaced those too?
Old 08-11-2009, 02:32 PM
hinow41's Avatar
Ok that little white part should just turn and pop right out. Is there a slot on the white piece? If so they are the same thing as the brown pieces in my how to. To get them out just use a small flat head screw driver and turn it and it will come out. You need them so make sure you don't brake it. Find a tool to bend the stock leds metal prongs and take the led out then put your colored 3mm in and work the prongs into the slots on the white piece. Then just turn it back in and your set. If you want to test it before you put everything back togeter just go out to your car and plug it in and turn on your Day time runinng lamps and everything should light up. If not check the conection on the led and make sure you get 12v leds! I can't stress that enough. if you can't find them use this site. http://ordering.digikey.com/ordering...&source=search GO to their live chat and they will get you the product number.
For the 09 steering wheels What you need to get are called suface mount leds. Im not sure on the size because iv never did an 09. I know that the stock raido has them and so do the stock gauges. Here is a great site for ordering them. http://www.ledtronics.com/Products/cat1.aspx?P=C0D10
They come in a wide selection of sizes. Iv never opened up the steering wheel of the 09s. Do they have the regular 3mm leds in side? If they do just replace those. If not get the surface mount ones.
Any more questions feel free to ask
Old 08-11-2009, 04:17 PM
Grich171's Avatar
each button has its own little baby led lol i gave up on changing the bulb i just got red cellophane and put it over top and that works fine...just trying to find out for the gauges in the DIY thread on this site if u just take the blue color off with the paint thinner if it will shine threw clear white instead of the ugly yellowish white color it is stock
Old 08-11-2009, 05:25 PM
hinow41's Avatar
Dam lol cellophane works but some times its a bitch to get right. Dam if you lived close I would help you out NP. A sharpie works too but it fades with time. I didn't know the 09s had the little leds >< They are a PITA to work with.
Old 08-11-2009, 05:50 PM
Grich171's Avatar
yeah well we will see what happens tonight when i can actually see lol ill take some pics n show how it looks
Old 01-04-2010, 07:52 AM
iboost's Avatar
sub'd for later
Old 01-07-2010, 08:05 PM
Dragonsfire12345's Avatar
lol went to radio shack and I completely got the wrong size.... so Now I have 9 red leds sitting here at home.
Old 01-08-2010, 12:23 AM
G5 SE BLEU 2008's Avatar
look good but I prefer my interior lighting
http://cobaltssquebec.forumup.ca/vie...cobaltssquebec
bigdeertz
11-17-2016 09:41 AM
Builttss
10-04-2015 10:21 AM
nathan112i
09-30-2015 07:12 PM
Cobalt_Daddy
09-27-2015 06:59 PM
dieGone
09-23-2015 10:20 AM
Quick Reply: Interior: Hinow41 led button mod
