Electrical: How To Aftermarket Fog Lights Use OEM Fog Light Switch
Aright well to start with, I still wanted Fog Lights even though my RKSport bumper doesn't come with Fog Light locations... Simple fix. As a note my fogs are from K2Motor.com under Fog Lights>Universal> 9 LED Universal Fog Lights. These came with a relay, light, brackets, wiring, EVERYTHING you need except the tools and know how to install.
What you'll need:
Tools
Electrical Tape
Zip Ties
Add-a-fuse(OPTIONAL)
First Off. This way will make it so the new universal fogs of your choice work with the OEM Fog light button on your car... If you had them. If not you'll need to make your own button.
1. Install Fog Lights. I found a simple location is the two holes already drilled in the crash bar in the front bumper area. You should be able to use these holes easily unless you have a HE/IC that uses them. I don't, so if you used these holes you'll need to find another way to mount them... Sorry
2. Watch this video and it should explain a good amount of the how to... I'll answer any questions and update this post if things are asked.
LIGHTS ON AND OFF:
Thanks,
Bratboy90
What you'll need:
Tools
Electrical Tape
Zip Ties
LIGHTS ON AND OFF:
Thanks,
Bratboy90
z28addiction
09-28-2015 12:03 AM
