Originally Posted by Illini_06SS
(Post 4806633)
Honestly, it might be slightly larger, but there is nothing that's anywhere close to the snout on my M62 (and I have an Automatic as well). I need a picture to see what exactly you're talking about... I have a meeting in 10 minutes so I'll be away from my desk for 30 mins or so, FYI.
Also... My oh my... You're still a 2.4 (the displacement of your engine isn't changing at all...) and yes, the LSJ throttle body is larger than the LE5 TB to allow for more air to flow. |
Hi guys this topic is great
I need to wire the 2.5 tmap for the map sensor, it's not a problem but for the IAT (from mAF) to the tmap, I read all this tread and didn't find how to do it hope you could help me thanks |
it should be in beck's how-to
Originally Posted by Garrettsi
(Post 4858484)
Originally Posted by Gene Culley
(Post 4861318)
If you're looking to do the IAT2 conversion I had it in my thread in the LAP section.
now I need to rescale de map for the 2.5 bar, and the 60 lbs injectors otherwise someone as this base calibration file to help me |
sub'd for future plans..
by any chance does any one have a how to.. for tunning the maf sensor ..
for tuning it? you'd probably want to check the tuning section.
You dont mean installing it do you? |
no i just need help tunning it...
you're gonna want to find a tuner then. Almost none of the people who did this are tuners..
install wideband
connect to HPT create custom PID for WB force car into open loop use PCM controls Log WB AFR Error Past % in high/low respectively done. no problem. |
**goes crosseyed**
On your diagram for the 2.5bar MAP, we use the stock map wires plus wire from the MAF? and we cut/remove them from the MAF sensor, or are we tapiping into it? (The black and a tan wires)
cut them in
Originally Posted by HunterKiller89
(Post 5108500)
cut them in
thanks! |
cut them from the maf and run them to the map.
Originally Posted by hoffa
(Post 5109200)
approved!!!
One last question about the maf, I have 2 tan looking wires one slightly darker, which one do I use? Im remember reading this same question somewhere but for the life of me I can not find it
Originally Posted by EcoTecDriver
(Post 5109354)
this sounds like a pita
nah its alot easier then it sounds, + I can run the 2.5bar instead of stock and read Ia2's
One thing I have been thinking about is We are removing the ground from the MAF, so dont we need to replace the it, with a new ground in order for the MAF to work? |
That makes since no other electrical piece works without being grounded
(Post 5109835)
One thing I have been thinking about is We are removing the ground from the MAF, so dont we need to replace the it, with a new ground in order for the MAF to work? cuz you don't cut the ground, you cut the low reference and ia2 signal wires. |
Oh well that takes care of that question
