2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old 11-18-2008, 01:05 PM
  #151
averagewhiteboy's Avatar
I have a narrow just for show.. But if I do this I'll get a wide.. The narrow is basically just a light show.. Not too accurate.. But the wide is pretty costly in comparison..
Old 11-18-2008, 01:46 PM
  #152
HunterKiller89's Avatar
Originally Posted by Motoxer4life
Oh ok. So you think the regular gauges from that site will be good then just get a wideband for the air/fuel?
yea. that should be fine
Old 11-18-2008, 03:45 PM
  #153
Motoxer4life's Avatar
And is the intereceptor a good guage also? I thought i was looking at that one and it displays like 30 different things...
Old 11-18-2008, 03:53 PM
  #154
pjk91's Avatar
it's a good gauge.
Old 11-18-2008, 09:50 PM
  #155
And what all does the interceptor gauge measure?
Old 11-19-2008, 02:34 PM
  #156
pjk91's Avatar
I thought you looked it up? You can have it measure nearly anything as long as you have the correct input.
RPM
MPH
Intake Air Temperature pre intercooler
Intake Air Temperature post Intercooler *
Mass Air Flow Sensor Frequency *
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure in PSI (Boost pressure)
Supercharger Inlet Pressure *
Ignition Advance
Knock Retard *
Engine Run Time
Battery Voltage
Throttle Position Percentage
Engine Load
Instantaneous fuel economy
Horsepower
Analog input #1
Analog input #2
Old 11-19-2008, 03:46 PM
  #157
So basically, instead of buying three different gauges then the one interceptor would be all i need? i know its expensive, but how much are all of these "inputs" your talking about?
Old 11-19-2008, 05:09 PM
  #158
pjk91's Avatar
The interceptor connects to your OBD II plug. It can display only two at a time. So you want a boost gauge, and afr at the minimum. You can have your interceptor do that by purchasing wideband sensor that has 0-5v output (like the Innovate LC-1) and a boost gauge. I'm not sure how you would get the Interceptor to read boost electronically, so maybe Hunter can answer that. EGT, get a egt sensor with 0-5v output. Those two can be your analog inputs. The rest of the inputs on this list a factory inputs.
Does that make sense?
Cost breakdown
3-pillar pod - $100~
Interceptor - $240~
Manual Boost Gauge - $80~
EGT sensor - $100~
Widebad O2 - $200~
Or you can get 3 analog gauges.
boost - 80
egt - 100
afr - 250
Does the same thing but not fancy.
Old 11-19-2008, 06:21 PM
  #159
IonNinja's Avatar
i'm pretty sure you'll need a mechanical boost gauge since the stock ECU does not read boost by default.
also the interceptor is only going to display parameters that your ECU has sensors for + analog input(s)
I would just get a wideband and a boost gauge if it was me...you'll spend more getting an LC1 + interceptor than you will with something such as an AEM EUGO
Old 11-19-2008, 06:32 PM
  #160
This sounds like a big headache. lol.
Old 11-19-2008, 09:46 PM
  #161
I know, i just want some simple gauges lol
Old 11-20-2008, 12:37 AM
  #162
Not just the gauges, but everything in general.. I'll have to show the info I printed out to my two friend who've gone turbo on their cars.. They can explain some of the details to me of what some of it is..
Old 11-20-2008, 11:21 AM
  #163
IonNinja's Avatar
it doesn't seem that hard to me...
the biggest pieces are supercharger, intake manifold, lsj throttle body, idler/tensior setup, intercooler pump, heat exchanger...everything else is little odds and ends.
besides its cheap...although you can always go turbo for double the price if you need a complete kit
Old 11-20-2008, 12:11 PM
  #164
haha I have no need for the set-up right now.. But after I complete some more stuff I may look into it..
Old 01-21-2009, 01:54 PM
  #165
rockstar014's Avatar
im soooo doing this
Old 01-28-2009, 10:50 PM
  #166
Dragonsfire12345's Avatar
what are the GM part numbers for the map sensor, and map sensor pigtail?
Old 01-29-2009, 06:39 PM
  #167
pjk91's Avatar
the pigtail is $116 jsut so ya know. i don't have the p/n handy but I'll get it for you in a day or two. I had to get a pigtail last week. tmap sensor on the IM right?
Old 01-29-2009, 07:08 PM
  #168
the MAP sensor is $85
how is the pigtail $116? Is that the engine harness? I think the TMAP sensor plugs directly into the engine harness
Old 01-29-2009, 08:05 PM
  #169
well I found the map sensor, tensioner, and idler. Just couldn't find the pigtail.
***found on www.gmpartsdirect.com***
map sensor- 47 bucks
belt tensioner- 126 bucks
idler pulley- 40 bucks
Old 01-29-2009, 08:09 PM
  #170
SRodSS007's Avatar
omg this kit was sucha hassle. after i pieced it all together it totallt was a waste.... just lil things here and there.. ugghghgh
Old 01-29-2009, 08:11 PM
  #171
as in you had extra parts? or too few parts?
Old 01-30-2009, 01:01 PM
  #172
pjk91's Avatar
not sure what it comes with yet, it's still "coming" according to dealer. I ordered last week. Its not a hassle if ya know what you're doing it's basic mechanical stuff, and then you need someone to tune or tune yourself.
Old 02-04-2009, 08:17 PM
  #173
bulls'ss's Avatar
im doing this swap on my 2.4 and i have basically everything but the wideband kit. how hard is it to install the wideband, boost gauge?
Old 02-08-2009, 09:36 PM
  #174
cobaltss86's Avatar
ive ordered the whole kit in the last 2 days except the wideband ill order tomorrow
Old 02-09-2009, 01:00 AM
  #175
Calibrah's Avatar
How much power does a 2.4 put out using this setup?
Quick Reply: 2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
