2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old 03-31-2010, 02:07 PM
  #251
rossshady120's Avatar
Originally Posted by Illini_06SS
Honestly, it might be slightly larger, but there is nothing that's anywhere close to the snout on my M62 (and I have an Automatic as well). I need a picture to see what exactly you're talking about... I have a meeting in 10 minutes so I'll be away from my desk for 30 mins or so, FYI.
Also... My oh my... You're still a 2.4 (the displacement of your engine isn't changing at all...) and yes, the LSJ throttle body is larger than the LE5 TB to allow for more air to flow.
thats what i told him my inches are still the same but he thinks different because i got a bunch of 2.0 LSJ parts. The shop is moving the brake lines down about 3" inches so we shall see where this part of the story takes me
Old 04-19-2010, 10:10 PM
  #252
Garrettsi's Avatar
Hi guys this topic is great
I need to wire the 2.5 tmap
for the map sensor, it's not a problem
but for the IAT (from mAF) to the tmap, I read all this tread and didn't find how to do it
hope you could help me
thanks
Old 04-20-2010, 02:08 AM
  #253
HunterKiller89's Avatar
it should be in beck's how-to
Old 04-20-2010, 07:42 PM
  #254
Gene Culley's Avatar
Talking
thanks
If you're looking to do the IAT2 conversion I had it in my thread in the LAP section.
Old 04-21-2010, 07:15 PM
  #255
Garrettsi's Avatar
ok I found the wire on my LSJ wiring, TAN WIRE is IAT
now I need to rescale de map for the 2.5 bar, and the 60 lbs injectors
otherwise someone as this base calibration file to help me
Old 04-26-2010, 10:59 PM
  #256
mrgrinch's Avatar
sub'd for future plans..
Old 04-29-2010, 12:37 PM
  #257
Team_Overdose's Avatar
by any chance does any one have a how to.. for tunning the maf sensor ..
Old 04-29-2010, 02:46 PM
  #258
for tuning it? you'd probably want to check the tuning section.
You dont mean installing it do you?
Old 04-29-2010, 05:08 PM
  #259
no i just need help tunning it...
Old 04-29-2010, 08:12 PM
  #260
you're gonna want to find a tuner then. Almost none of the people who did this are tuners..
Old 05-06-2010, 09:12 PM
  #261
pjk91's Avatar
install wideband
connect to HPT
create custom PID for WB
force car into open loop use PCM controls
Log WB AFR Error
Past % in high/low respectively
done. no problem.
Old 06-17-2010, 10:51 PM
  #262
StevoElSupremo's Avatar
**goes crosseyed**
Old 07-19-2010, 03:40 AM
  #263
EcoTecDriver's Avatar
On your diagram for the 2.5bar MAP, we use the stock map wires plus wire from the MAF? and we cut/remove them from the MAF sensor, or are we tapiping into it? (The black and a tan wires)
Old 07-19-2010, 06:37 AM
  #264
cut them in
Old 07-19-2010, 12:20 PM
  #265
Originally Posted by HunterKiller89
cut them in
as in remove the wire from the MAF and run to the Bar harness?
thanks!
Old 07-19-2010, 02:14 PM
  #266
hoffa's Avatar
cut them from the maf and run them to the map.
Old 07-19-2010, 03:01 PM
  #267
Ok thank you, I just want it to be CLEAR.
Old 07-19-2010, 03:06 PM
  #268
Berto09ss's Avatar
approved!!!
Old 07-19-2010, 03:21 PM
  #269
One last question about the maf, I have 2 tan looking wires one slightly darker, which one do I use? Im remember reading this same question somewhere but for the life of me I can not find it
Old 07-19-2010, 06:03 PM
  #270
one should be tan, the other brown. if you have two tan wires, then they will have stripes. I cant recall specifics on the colors though...best to check the OP's diagram
Old 07-19-2010, 07:09 PM
  #271
Pedobear's Avatar
this sounds like a pita
Old 07-19-2010, 11:30 PM
  #272
nah its alot easier then it sounds, + I can run the 2.5bar instead of stock and read Ia2's
One thing I have been thinking about is We are removing the ground from the MAF, so dont we need to replace the it, with a new ground in order for the MAF to work?
Last edited by EcoTecDriver; 07-19-2010 at 11:30 PM. Reason: Automerged Doublepost
Old 07-20-2010, 03:29 PM
  #273
Pedobear's Avatar
That makes since no other electrical piece works without being grounded
Old 07-20-2010, 03:38 PM
  #274
hoffa's Avatar
are you talking about what is needed to run to the map sensor for this install?
cuz you don't cut the ground, you cut the low reference and ia2 signal wires.
Old 07-20-2010, 03:40 PM
  #275
Pedobear's Avatar
Oh well that takes care of that question
Quick Reply: 2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
