2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
#251
Honestly, it might be slightly larger, but there is nothing that's anywhere close to the snout on my M62 (and I have an Automatic as well). I need a picture to see what exactly you're talking about... I have a meeting in 10 minutes so I'll be away from my desk for 30 mins or so, FYI.
Also... My oh my... You're still a 2.4 (the displacement of your engine isn't changing at all...) and yes, the LSJ throttle body is larger than the LE5 TB to allow for more air to flow.
#252
Hi guys this topic is great
I need to wire the 2.5 tmap
for the map sensor, it's not a problem
but for the IAT (from mAF) to the tmap, I read all this tread and didn't find how to do it
hope you could help me
thanks
thanks
#255
now I need to rescale de map for the 2.5 bar, and the 60 lbs injectors
otherwise someone as this base calibration file to help me
#261
install wideband
connect to HPT
create custom PID for WB
force car into open loop use PCM controls
Log WB AFR Error
Past % in high/low respectively
done. no problem.
connect to HPT
Log WB AFR Error
done. no problem.
#263
On your diagram for the 2.5bar MAP, we use the stock map wires plus wire from the MAF? and we cut/remove them from the MAF sensor, or are we tapiping into it? (The black and a tan wires)
#269
One last question about the maf, I have 2 tan looking wires one slightly darker, which one do I use? Im remember reading this same question somewhere but for the life of me I can not find it
#272
nah its alot easier then it sounds, + I can run the 2.5bar instead of stock and read Ia2's
One thing I have been thinking about is We are removing the ground from the MAF, so dont we need to replace the it, with a new ground in order for the MAF to work?
Last edited by EcoTecDriver; 07-19-2010 at 11:30 PM. Reason: Automerged Doublepost
#274
cuz you don't cut the ground, you cut the low reference and ia2 signal wires.
