Go Back  Cobalt SS Network > General > How to Guide
How To: Beck’s 2.4L Supercharged Build Walkthrough >
2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Old 12-14-2012, 10:00 PM
  #301
Liked 0 Times in 0 Posts
amazing man may i ask a total price range
jfin is offline
Old 12-21-2012, 11:39 AM
  #302
pjk91's Avatar
depends on if you get your parts new, used, rigged or pretty, tune yourself or someone else tunes. 750-1500+ is a reasonable range.
pjk91 is offline
Old 03-04-2013, 08:38 AM
  #303
Liked 1 Time in 1 Post
Think this needs to be bumped up..lol
Tjolley is offline
Old 04-15-2013, 10:56 AM
  #304
im going from the 2.0ss/sc pulling the engine out and putting the 2.4 in do you know if the exhaust will bolt up?
and does anyone know of a tuner in the richmond va area?
brewster is offline
Old 04-16-2013, 12:16 AM
  #305
Beck's Avatar
Should bolt up just fine.
Beck is offline
Old 08-20-2013, 11:11 AM
  #306
I can use the 2.5 bar sensor right? I don't need to spend 70 bucks on the 2 bar sensor that zzp sells for the LE5?
Chaos_Six is offline
Old 08-20-2013, 11:13 AM
  #307
It'll take a pigtail and rewiring but yes
drumrush is offline
Old 08-20-2013, 11:15 AM
  #308
Liked 4 Times in 3 Posts
It'd actually be better lol. Well atleast it was for me idk what the rest do. I rewired pigtail in and then took the iat wire from the maf and wired it into the iat2 wire from the 2.5 so I can now monitor iat2 temps
Twoozofjuice is offline
Old 08-20-2013, 11:19 PM
  #309
Yay! 70 bucks saved :P
Old 09-01-2013, 11:07 AM
  #310
Because I can't find it anywhere, how far does the alternator have to be spaced out? 1/2 inch?
Old 09-02-2013, 01:05 AM
  #311
You shouldn't have to space the alternator at all? I didn't have to anyway. We just removed it, installed some parts and reinstalled it.
Jacob4ta is offline
Old 09-02-2013, 02:37 PM
  #312
Beck's Avatar
depends on the pulley set up you're using. If using the oem LSJ pulley setup the alternator is spaced by the bracket that holds the tensioner pulley. I believe its about 1/2" space but i cant confirm that.
Beck is offline
Old 09-03-2013, 01:47 PM
  #313
Another noob question. -_- Where did you get your injector harness? I got one from ZZP and it's for the LSJ...
Old 09-03-2013, 11:58 PM
  #314
Beck's Avatar
make your own, Buy the injector pigtails and wire them in to your oem harness. There's a few other things you'll have to wire in like the MAP sensor and also the throttle body pigtails unless you've got a harness for that
Beck is offline
Old 09-04-2013, 12:16 AM
  #315
Okay. Yeah I have the throttle body harness. As far as an LSJ MAP sensor and pigtail, do you have extras of them by any chance? I asked Mongo, he wasn't sure.
Old 09-04-2013, 07:58 PM
  #316
Beck's Avatar
nope i dont have an extra one, but i believe i posted the part numbers in the original post.
Beck is offline
Old 09-04-2014, 08:03 PM
  #317
New to site have questions
Is there anyone still around that can answer questions to this build
Glum2.4l is offline
Old 09-04-2014, 11:43 PM
  #318
Liked 2 Times in 2 Posts
Yeah plenty.
andrewcarr1993 is offline
Old 09-05-2014, 03:53 AM
  #319
If I'm using the intercooler pump off the lsj do I still need to get the bracket or is there one on the lsj I can use where can I find some good affordable injectors and harness also will the stock HE on the lsj work if so how would I plumb it and lastly for now does any1 have a picture of the custom idler pully and it mounted on the car Ty
Glum2.4l is offline
Old 10-19-2014, 10:31 PM
  #320
For IC pump you can use the stock lsj brackets or you can buy zzp's little bracket and mount it pretty much anywhere.
stock H/e works great use it.
ask around for injectors someone is always selling em
sandman is offline
Old 11-02-2016, 02:22 PM
  #321
What supercharger did you use and cost
Beck how much did this build cost what's the finished products power output and what supercharger did you get.
Dashernex is offline
Old 05-01-2017, 12:19 PM
  #322
Liked 93 Times in 89 Posts
I saw someone did this to an 08 Sport... Does the ABS get in the way of a CAI?
Researching I have found some. ZZP said it took a special CAI which is why I asked.
Henry3959 is offline
Old 06-18-2017, 11:10 PM
  #323
The list of items and work necessary to do this that isn't in the build is too long to list. If your interested in putting a SC on a 2.2 or 2.4, contact me.
Old 06-23-2018, 01:49 PM
  #324
Hi there - I was reading the parts list for the LSJ supercharger swap - one item is a bit confusing:
Stage 2 Belt (Part# 12597993; requires one rib be cut off)
Ok can someone show me what is meant by cutting one rib off the belt?
OhSixBalt is offline
Old 06-23-2018, 03:07 PM
  #325
The OEM belt is a 6 rib belt. The LE5 has 5 rib accessory pulleys. You can either source a 6 rib balancer, AC Compressor and alternator or cut one of the ribs off to fit the OEM accessory pulleys. A new utility knife can easily cut an entire rib off if done safely.
The following users liked this post: Henry3959
OhSixBalt (06-23-2018)
Quick Reply: 2.4 LE5 Engine: How To: Beck’s 2.4L Supercharged Build Walkthrough
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
