Drivetrain: "How to" fill your motor/tranny mounts with polyurethane
Old 05-17-2007, 10:51 AM
QuikFKR's Avatar
before and after pics.......
Rear mount
Front mount
Middle stage (bout 2-3 days)
Rear mount:
Front mount:
all done:
Rear mount
Front mount
Old 05-17-2007, 11:02 AM
Edubs's Avatar
Rick1217...
Use this link for help with removing the fuse box. It's a great step by step guide:
LSJ Removal Manual
Old 05-21-2007, 06:06 PM
dhutch's Avatar
Does this mod actually get rid of that much wheel hop?
Old 06-05-2007, 09:43 PM
redline24's Avatar
So if I use my jack and a block of wood under the motor can I remove the two lower motor mounts?
Old 06-24-2007, 09:12 PM
Julex's Avatar
I am doing my clutch and I have the engine being held by 1 motor mount (passanger side one) and I have a Jack with 2 pieces of wood on top of the jack against the engine oil pan, and no problems, but be VERY careful, oil pan = Cast and it can crack real easy to jack it VERY slow, and stop as soon as you see the engine try to move up. Also an even safer way is to have an engine hoist hooked to the engine hook, and lift up a little with that. Same effect, just hoist is much safer. the other 3 mounts are on my floor.
Also this is a between method of "real-deal" mounts and stock ones. I personally have trued both real mounts and filled mounts on my old civic and it was the same. obviously I like cheaper method. And I like doing everything myself. Good luck
Old 06-24-2007, 09:26 PM
beamSS's Avatar
can you do this without removing the mounts?
Old 06-27-2007, 11:11 AM
rick1217's Avatar
Maybe, but it would make a big mess and be hard to do it properlly. I would just take them out, it is pretty easy with basic tools, just take your time......
Old 06-27-2007, 12:00 PM
Ric
Ric's Avatar
The stuff your using, is it the foam insulation?
Old 06-27-2007, 07:10 PM
Julex's Avatar
basically get whatever you want. if you want harder mounts, use harder stuff like poly-urethane, want softer then you should use silicon or something that has alot of squish to it. Either way, anything you do will add more stiffness, anything that fills in the air will add SOME stiffness.
And no I wouldn't recommend doing this with out taking mounts off. You need to fill them and let the fill harden a little bit, atleast a days time. If you don't you'll end up with less fill in the middle where you want it.
Old 07-16-2007, 11:05 AM
ridemlow03's Avatar
Also, to speed up the curing process, put it in the oven. Bake it at like 150-175 for about 3 or 4 hours and it will cure alot faster.
Old 07-16-2007, 11:17 AM
  #36
Julex's Avatar
Well anyways I did the 3 trans mounts but not the engine mount and it hold on for dear life now, to bad the tires can't say the same lol. Stage 4 clutch + fidanza flywheel and I still couldn't get the wheel to bounce, so I would say a success. Also for anyone looking to get even more rigid design, put flat stock of aluminum or steel and press them into the mounts so there is even more mass of solid so once the mounts move to the fills stretch point it will start to compress the flat stock, which since it's beefy will not compress hence semi solid mounts. Good luck!
Old 07-16-2007, 05:23 PM
  #37
ridemlow03's Avatar
Yeah I just got done of mine. Meant to take pictures of the steps on how to do it for this thread but got too excited and forgot. I did my front, rear and passenger mounts. I love it, havent got on it too hard because imma let it cure for a little while longer so it will be good but damn the car vibrates like hell. I know my girls going to like it . Good info about the more "solid mounts", but thats not a good idea if its a daily driver. My brother had solids on his nova and he broke a couple things. Good idea though, better for strip only.
Old 07-17-2007, 02:41 AM
  #38
lrk322's Avatar
Is the extra vibration bad enough to outway the increased performance if daily driveability is a big concern?
Old 07-17-2007, 04:45 AM
  #39
ridemlow03's Avatar
Yeah, the only time it vibrates is when its at idle and when your pulling off. When your at idle, you can feel it but its not bad. With the music up a little you forget about it, but when your pulling off and if you dont give it enough gas, then you will fill the vibes more. I used something different then what most people use. I used Devcon Flexane 94, 40 dollars for it and its enough to do the job. I filled in my front and rear tranny mounts, and the top engine mount. Mines a daily driver and I already love it. I got it done today after baking it in the oven for 4 hours at 175 degrees. I then let it cool off for about 1 hour because it was freakin hot and then installed them. Took it easy driving around for about 50 miles and I just couldnt hold back no more. I pulled up to a stop light and just launched it. BOY let me tell you, the car has no wheel hop and spins alot less. Ive never had the clean of a pull of in the car since I got it. Its get so much better traction and now Im not scared of breaking transmission casing or axles because it has no wheel hop. I highly recommend doing it. Imma also buy the Ingalls Torque Dampener and traction bars just to give me that much more reasurrance. Good luck and i would deffinetly do it. If you have any questions just pm me and i will help you out with the process in where to get the stuff I bought and anything else you need.
Old 07-17-2007, 02:41 PM
  #40
lrk322's Avatar
Thanks so much for the detailed response! Sounds like its worth it for the improved traction. Daily driveability is my main concern so I guess Ill just have to see how bad the wheel hop is.
Thanks!
Old 07-24-2007, 07:39 PM
  #41
06Pursuit's Avatar
finaly did them. holy what a diffrence. deffenatly recomend this to everyone!
Old 09-01-2007, 11:52 AM
  #42
joeworkstoohard's Avatar
incase anyone cares...
befo...
afta...
also, i have a toaster oven that i use to cure paint on RC car parts and things... setting it at like 160-175 for a few hours REALLY helps make it set.
Old 12-21-2007, 04:05 PM
  #43
hungryhip-ccp's Avatar
thanks man awsome how to im going to attempt tonight after work at my shop we have a press so im going to try to save the old ones
Old 12-23-2007, 08:14 PM
  #44
LopsidedJester's Avatar
i didn't see this how to until today, but i already filled my front and rear trans mounts after seeing a post from a guy with a civic on another site. This definitely makes the car feel a whole lot better when taking off, i used 3m polyurethane windo weld, worked like a charm but gets very messy very quick if you're not careful.
Old 12-23-2007, 08:17 PM
  #45
Dragonsfire12345's Avatar
yeah it is very easy to do this, and does get messy lol.
Hey LopsidedJester I like your exhaust.
Old 03-08-2008, 12:52 AM
  #46
tru2nrtt777's Avatar
I am so gonna do this when I get time.
05-28-2022 03:47 AM
01-12-2016 12:01 AM
OrangeCoba
10-01-2015 10:00 PM
n20saturn
09-30-2015 12:26 AM
09-27-2015 08:53 PM
Quick Reply: Drivetrain: "How to" fill your motor/tranny mounts with polyurethane
