Drivetrain: HOW TO Fix Linkage Roll Pin on Transmission
Old 08-06-2009, 01:44 PM
  #126
rallycobalt06's Avatar
sounds exactly what happens when your roll pin breaks.
if you have a warranty left on your car, get it towed to the dealership..... if not, follow this HOW TO
i've been there and done that.
Old 08-06-2009, 01:48 PM
  #127
Snuggs's Avatar
perfect...
actually have 90k on the car. she's been a champ. first replacement (obviously) of the pin. and like i said above.. i like to drive so i haven't exactly been easy on her. just driven like it should be.
thanks rally - hope you find your bucket - i'll keep my eyes out while i walk to the auto parts store.. lol
Old 08-06-2009, 01:52 PM
  #128
wow! that's pretty good for the roll pin to lask 90k.
oh dont worry about the bucket..... i give on it i'll just ask Santa to bring me a better one this Christmas.
Old 08-06-2009, 01:55 PM
  #129
Snuggs's Avatar
yeah... she's pretty as new too... of course the hail storm and full body makeover helped... threw on a cf hood in the process for 150.00... why not. haha.
do you think that the missing 2nd was a predecessor to the lost of all? that i really broke the pin a long time ago and now just have the full breakage or slip out? i'll know more after i dig in there i guess...
Old 08-06-2009, 02:03 PM
  #130
it's really hard to say. because i basically went thru the same thing you did..... i'm lead to believe that the roll pin actually bends as a "warning" that it's going to break very soon. unfortunately it doesn't last much longer after bending. mine was broke into 3 little pieces. what i did was buy a roll pin set from AutoZone, it was $1.99, i put 2 smaller pins inside the correct size pin to make it stronger. it's worked perfectly fine for me since then and that was roughly 10k miles ago.
Old 08-07-2009, 11:43 AM
  #131
Snuggs's Avatar
wow.. ok.. ftl. here's where i'm at.
got the pin out.. most of it.. that's the problem.
it's been split into 3.. and the pin i have is a bad a* pin compared to the pics... mine is wrapped in a spiral reinforced the whole way through... anyway i have the 2 ends out.. and i have a (roughly) 1/4" piece that is lodged in the middle of the linkage..
I haven't been able to fit a rod push into that area... no idea how you guys did that one.. so i've been trying a alan wrench with pressure on it from a wonder bar being leveraged off of the side of the engine bay.. wiggling the casing... no go.
anyone else run into this?
I do see what you mean about the smaller one inside the other.. i'm planning on doing that as well.. I have pics. should i add to this page?
help...
oh, and now it's raining.. and i just moved here so no one to help push it UP the driveway into the garage.. lol (facepalm)
Last edited by Snuggs; 08-07-2009 at 11:44 AM. Reason: adding more of the sob story
Old 08-07-2009, 12:49 PM
  #132
CleverOne's Avatar
Guys, that pin is supposed to break and be weak, dont reinforce it you wil break your tranny. its either that 1.99 pin or your transmission.
Old 08-08-2009, 10:37 AM
  #133
Snuggs's Avatar
Ok I just finished and she's back to her short shifting self. woot woot!
I'll throw some pics up here if anyone is interested.. I have pics of reinforcing the pin...not to the point that it won't break, but I think it matches the stock pin.
Also I have a picture of the tranny mount out.
I've never claimed to be a mechanic and anyone who knows me laughs at my ability to drive farrr out ranking my wrench skills at this point. haha. we all have our talents right?
anyway.. how do you post photos... sorry newb question.. but where do you put them to url them here?
Old 08-08-2009, 11:16 AM
  #134
NVMYCOBALTSS's Avatar
photobucket
Old 08-08-2009, 12:00 PM
  #135
Snuggs's Avatar
Shee
in my car... Driving... Stuck in 5th... Out of ideas... No where near home
Un woot
Old 08-08-2009, 07:21 PM
  #136
Snuggs's Avatar
Wow, ok apparently the pin came out. Luckily limped it to a shop that my buddy works at and installed a new pin... A tension pin from Ace Hardware. Seemed more heavy duty. We'll see how this one works, pasted som weak grip tight in there too.
He's checking on the size of the replacement pin from chevy.
What a day
Old 08-08-2009, 11:18 PM
  #137
*boostinss*'s Avatar
LOL i had this pin break on my about 5 times. so i got real pissed off then put a bolt in it thinking thats should do it NOOOO! the bolt broke so i bought the thickest hardend hex bolt that would fit in there. i mean i have to like press it in with channel lock plyers. lol i has held up far about 5 weeks now. and if you want the see a Really!!!! tight shifter you should see mine lol.
Old 08-09-2009, 12:08 AM
  #138
06cobalt racer's Avatar
what size of hex bolt did you use?
Old 08-10-2009, 10:20 PM
  #139
the biggest one that would fit in there lol. it was so tight i had to get channel lock plyers to press it through.idk the size i just found a hex bolt in my basement. srry boss.
Old 08-16-2009, 06:24 PM
  #140
rocco11189's Avatar
This just happened to me not sure if its the roll pin yet but is there anyway to get the stock gm roll pins? I'm at 38,000 miles and not sure if this is covered under the 60,000 warranty i have. Anyone able to help me? lol
Old 08-16-2009, 06:28 PM
  #141
EatonTVS07's Avatar
im sure you could ask them.
i just replaced mine, i'm getting good at it only about 40 minutes with a break or so. i got a roll pin from nappa, filled it with magnasteel hopefully it holds a little longer.
Old 08-16-2009, 06:32 PM
  #142
rocco11189's Avatar
lol yea this happened to me at 330am coming home from work had to get my car towed front lower bumper got scraped and bent now i have to have that fixed
Old 08-17-2009, 01:34 PM
  #143
rocco11189's Avatar
whats the temporary fix for this so I could at least get my car home?
Old 02-26-2010, 11:45 PM
  #144
slvr 04 rl's Avatar
subscribed for home
Old 02-27-2010, 01:11 AM
  #145
ralliartist's Avatar
temp fix is just reaching down underneatch the fuse box and using your fingers to squeeze the roll pin back inside the linkage hammers. Just don't drive it hard after that.
Old 02-27-2010, 01:21 AM
  #146
09blackonblack's Avatar
this is only on the f35 right? not on the f23
Old 02-27-2010, 01:28 PM
  #147
right
Old 03-10-2010, 02:53 PM
  #148
BNS06Mike's Avatar
which way did you go about pushing the pin out?
i cant seem to figure out a way where the pin pusher is fitting well enough i can hit it with the hammer.
Old 03-10-2010, 03:04 PM
  #149
northvibe's Avatar
subbed incase of later issue :P
Old 03-11-2010, 01:05 AM
  #150
reason i asked is my shifter seems really loose and wiggly
Quick Reply: Drivetrain: HOW TO Fix Linkage Roll Pin on Transmission
