Go Back  Cobalt SS Network > General > How to Guide
How to install the "AEM intake" for your Cobalt SS/SC >
2.0 LSJ Engine: How to install the "AEM intake" for your Cobalt SS/SC
Old 06-26-2006, 09:33 PM
Nuclear's Avatar
Liked 0 Times in 0 Posts
sorry man i wasn't trying to put down AEM at all or your write up of the install, it was good
Nuclear is offline
Old 06-26-2006, 09:51 PM
how did you get more noticed torque from the AEM intake when the torque numbers are the same on both dynos?? I see the torque comes slightly sooner by 15lbs in 3800RPM but it's not anymore torque then when you dynoed stock. I don't get it.
Not bashing just trying to understand I guess. I can't feel 15lbs more torque. Car runs the same just pulls harder higher end with HP increase.
3fo893013L is offline
Old 06-26-2006, 09:52 PM
SS_SC_Cobalt's Avatar
Originally Posted by sneaky
Good luck with that plastic piping heat soaking all that hot air. The K&N's pipe actually reduces the heat soak you get with the plastic stock piping. So again, I paid for something shiney that has some use and looks good.
sneaky, plastic is more thermally stable than metal, meaning it WILL stay cooler...
SS_SC_Cobalt is offline
Old 06-27-2006, 12:11 AM
Originally Posted by denny
Congratulations with that. You just bought a nice and very expensive shiny new pipe that doesnt fit properly and uses a K&N oiled filter. Did you get a CEL yet, If yes then it's time to go clean that MAF sensor again.
that shinny pipe is better. take a look at the stock intake tube its all bent and not the same radius all around. the shinny intake tube we have is manderal bent meaning a better airflow. i mean thats what we waste all this money on a new cat-back right. im not just going to put a tip at the end?????manderal bent pipping is a bit better man.. ijen all the way
marzbarz is offline
Old 06-27-2006, 12:15 AM
Blown 4-banger's Avatar
At the track when I first got my intake, I opened the hood about 10 minutes after shutting the engine off. I felt the pipe it was really hot, then I started the car and 30 seconds later the intake tube was cool to the touch. Also, if you know how to oil a K&N filter you don't have to worry about "gumming" up the MAF sensor. I bought my intake from someone who was selling their car, so before I installed the intake I re-oiled the filter and re-oiled it right! I installed the intake and got a cel about a week later for about 15 miles then it went away and never came back and that was over 2000 miles ago.
Blown 4-banger is offline
Old 06-27-2006, 08:46 AM
denny's Avatar
Liked 1 Time in 1 Post
wow, bashing K&N are we? I have the intake and I have no check engine lights ever! I got it once. That was because it got wet from water. dried it and it was fine.
The trick with the K&N and the rest of them is to take the whole sensor off without taking a little bit off at a time. I took the whole thing off (wire harness and sensor as one unit not seperate). Good luck with that plastic piping heat soaking all that hot air. The K&N's pipe actually reduces the heat soak you get with the plastic stock piping. So again, I paid for something shiney that has some use and looks good.
That AEM intake is crap. That I would have to say that is the first time I've ever seen an AEM intake without a full piping. You might as well just take the stock piping off at the thorttle body and turn it into an SRI with what AEM gave you. Seriously.. you saved a whopping $80 but you only got "HAL F THE PURCHASE". Where's the rest of the intake?
As for K&N over oiling the filters I agree on that but a dry filter isn't going to do you a load of wonders either. Good luck cleaning it after you have to dip it in harsh chemicals like K&N does.
it's your purchase I'm just giving my input. I usually see AEM as performance but that is like removing the stock airbox and just putting a small pipe and a filter on the end. If I wanted that I would go to Murrays and buy a $30 K&N cone filter and some PCV piping because that's what you paid for.
Not putting you down, good write up but bitter about people who waste money on half purchases, to each there own.
EDIT: My dealership doesn't care about my intake. It's fine under the Moss Act they said.
Sneaky, First off you need to calm down o.k. Calling the AEM intake crap is uncalled for Now enough with this who is better b.s and lets all move on. This debate could go on forever! I made my decision and you made yours.
Have a good day
denny is offline
Old 06-27-2006, 08:59 AM
Have a good day
I edited it. Not to say that it wasn't uncalled for but someone has to defend K&N.
Old 06-30-2006, 04:16 PM
yoo
Hey nuclear, what are you running in the 1/4 mile with those mods, because thats my goal pretty much what you have? I'm hoping mid 13's?
Enufftogoaround is offline
Old 07-05-2006, 05:13 PM
denny's Avatar
It's all good bro
denny is offline
Old 07-17-2006, 12:21 PM
Uhhhh.. educate a noob on what a CEL is please?
Kemble is offline
Old 07-18-2006, 11:18 AM
  #36
I feel misled about the AEM intake. I know I shouldn't assume anything but who'd expect to buy a CAI kit and it's simply a filter and a small bracket/connector? Mine is scheduled for delivery and now I don't even want it. If we get no piping for under the hood, can someone explain what I see in this pic?
CEL=Check Engine Light
Livnlow is offline
Old 07-18-2006, 11:27 AM
  #37
basically you are seeing a stock pipe with a aem sticker on it
I have a friend with an injen used intake would you trade the aem for the injen?
Old 07-18-2006, 01:23 PM
  #38
hey denny is it possible to buy one of those filter by its self?
lmk thanks
John is offline
Old 07-18-2006, 05:49 PM
  #39
denny's Avatar
lmk thanks
Yeap it is. AEM sells them in a lot of different sizes. They now use the DRYFLOW on every kit they sell....no more old K&N
denny is offline
Old 07-19-2006, 08:54 AM
  #40
That's pretty cool. Thanks for sharing.
mbp422 is offline
Old 07-22-2006, 10:11 PM
  #41
Which intake is best? Injen? K&N? AEM? I've always had K&Ns on previous cars... but the fact that the AEM is a dry intake is making me think twice about the K&N...
EdPJ is offline
Old 08-09-2006, 11:01 AM
  #42
So you get an Injen or K&N intake system and you purchase a dry filter from AEM..... best of both. And while your at it, you purchase the AEM water thingy they sell so you dont suck in water and put it before the MAF and after the Filter.
1. You get a dry filter
2. You get the nice shiney pipe.
3. No CEL oily problems.
4. Sit back and have a beer.
I just want to know which brand has the widest intake diameter. Anyone?
Trag is offline
Old 08-23-2006, 08:22 PM
  #43
jbp or jpb whatever the brand name is its a 3inch every other pipe is the same its all personal preference
darrend3 is offline
Old 09-11-2006, 11:13 AM
  #44
I'd like to thank this how-to as I bought an AEM Intake for my ss-sc and installed it myself! It sounds great; so bad-ass! My car can finally breathe clean air... That GM stock filter sucks lol
firesting is offline
Old 09-11-2006, 04:22 PM
  #45
LewiSS's Avatar
Actually, the stock filter DOESN'T suck - that's the problem
LewiSS is offline
Old 02-18-2007, 05:48 PM
  #46
EmperorJJ1's Avatar
Liked 25 Times in 23 Posts
thanks.. the pics helped alot when installing my k&N
EmperorJJ1 is offline
Old 03-23-2007, 01:38 PM
  #47
07LaserBlueSS's Avatar
Great how to! Installing mine today!
07LaserBlueSS is offline
Old 03-25-2007, 11:40 PM
  #48
RedEcotecSS's Avatar
great how-to. thinking of ordering mine tonight. i actually perfer not to have a shiny intake pipe. so i think the AEM is for me. thanks again for the excellent how-to bro.
RedEcotecSS is offline
Old 09-30-2007, 09:25 PM
  #49
Degashoot's Avatar
Nice HT indeed.
I will be ordering the AEM shortly.
Degashoot is offline
Old 03-04-2008, 12:48 PM
  #50
can someone link me as to where to get he dry filter and the "Dry Thingy" lol
SSrob is offline
Quick Reply: 2.0 LSJ Engine: How to install the "AEM intake" for your Cobalt SS/SC
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
