Interior: How To Install An Auto Dim Rear–view Mirror
guys...
07-08 Chevrolet HHR Rear View Mirror OEM LKQ | eBay
25$
im gonna search and see if i can fin one with the same connector as ours, that would be nice, and i dont have OnStar as well.
25$
Im usually all in for anything that makes me cobalt nicer while making it less run of the mill. Not to mention I like some subtle details that a non cobalt person would notice.
This is one of those thiings!
If the the mirror you get has a chunk of harness with it you're good to go. Just pull one of the wires plug it into #13 slot on your car's harness. Run the wire to the sunroof switch and your done.
I didn't do the reverse wire, I have a tinted back window so it wouldn't make a difference anyway.
#36
#37
The plug for the one you have linked (in post #26) is the bigger 16 pin connector. If your current mirror has OnStar, you should have the bigger 16 pin connector already. If you don't have OnStar, you will probably only have the 8-pin connector.
#38
I'll have to look i have onstar and i think your right i already have the 16 pin connector
#40
You don't need onstar, I bought a mirror out of a 07 hhr it has auto dim, compass, and maplights with NO onstar. Just make sure you get the plug with some wire so you can extend it to where you need. Its a 16 pin plug and has 5 wires in it. I can tell you where to run them or look for my post in the electronics section.
#42
#43
well i just bought this one
but if you have/want to keep your onstar, heres another
07-08 HHR Rear View Mirror With OnStar OEM LKQ | eBay
#44
#46
No problem here's the pin outs for the 16 pin connector for the Non Onstar mirror
Inside Rearview Mirror (DD8) Pin Wire Circuit Function
1 0.35 GY 157 Interior Lamp Control
2-5 -- -- Not Used
6 0.35 D-BU/WH 149 Courtesy Lamp Supply Voltage
7 -- -- Not Used
8 0.35 BK 750 Ground
9 0.35 L-GN 24 Backup Lamp Supply Voltage
10 -- -- Not Used
11 0.35 D-GN/WH 2514 Keypad Signal (UE1)-- -- Not Used (DD8)
12 0.35 L-GN/BK 2515 Keypad Supply Voltage (UE1)-- -- Not Used (DD8)
13 0.35 PK 339 Ignition 1 Voltage
14 0.35 YE/BK 2516 Keypad Green LED Signal (UE1)-- -- Not Used (DD8)
15 0.35 BN/WH 2517 Keypad Red LED Signal (UE1)-- -- Not Used (DD8)
16 -- -- Not Used
2-5 -- -- Not Used
7 -- -- Not Used
10 -- -- Not Used
16 -- -- Not Used
#48
u have that for the onstar mirror by chance?
#50
here is is broken down
i did this to see what kinna bulb was in it(i like my aftermarket leds better)
i got lucky and lkq sent the harness with the mirror, so i just pulled the leads out of that connector to put into the one already in my car so i dont have to buy any new ones
