Appearance: How-To Install a Hide-A-Plate
Ok everyone, this is my very first How-To! I try to make things as easy as I can, having already installed the plate.
Let me know what you think!
http://www.youtube.com/watch?v=5NLNVCKUgLA
Cliff notes -
Directions were hard to understand, but once you do it, it seems common sense on what needs to be done.
Step 1 - Attach metal strip to hide-a-plate using 2 metal bolts and use the black rubber cap things on the bottom to lock them in. Snip ends of metal bolts off as close to the rubber pieces as you can.
Step 2 - Position hide-a-plate where you would like it to be under the front lip of the car.
Step 3 - Take 2 black screws and screw one in each slot closest to the plate holder. You should screw them into the lower lip. Keep them loose so you can manuever the plate back and forth to adjust it so it doesn't rub/not fold up all the way. Once, you get it lined up correctly screw all the way in.
Step 4 - Bend metal strip upward and screw another black screw into the plastic gaurd. Use a black clip on the back of the gaurd to hold screw inplace.
Step 5 - Snip off excess metal strip
Step 6 - Add foam pads to any contact points
Step 7 - Attach license plate to hide-a-plate with 4 black screws and you're on your way!
Cliff notes -
Delta coupe
09-30-2015 08:11 AM
