2.4 LE5 Engine: How To: Make a nice CAI
Old Jul 18, 2008 | 07:24 PM
BULLETSSMOKE's Avatar
basic GMPP short ram up to MAF sensor
stainless steel elbows and connectors from Summit Racing leading the short ram into a CAI down into the bumper
down through the air intake hole
down to the bottom of the bumper with a Fujita F5 filter
when my front bumper got backed into last year by a truck this little triangular hole was loose so i just removed it, which caused a lot more colder airflow
this all increased the airflow a good bit to the air filter and made it SUPER LOUD, as loud as my Megan 2.5 catback sometimes even louder....
pretty sick "custom" mod that gave me good gains, about 7whp"ish". i lost my tune and my car was slow because of it, then this setup was put together and it seemed like i got all of that power back, my track times and my Dashhawk times are more or less the same. and i STILL dont have a tune, but i cant wait to get one with this new intake, I might see decent gains better than my last tune.
This is my 1st how to so its kind of sloppy, I have another helpful one I'm about to post up shortly for the e-brake.
Old Jul 23, 2008 | 04:54 PM
Halfcent's Avatar
I'm old school
That piece of plastic you removed was a splash gaurd. Your filter will get wet. Having it there will not reduce the available air to the filter.
Old Jul 23, 2008 | 04:56 PM
I drove it in an Atlanta thunderstorm last night with falling trees and hail and its still good
Old Jul 23, 2008 | 09:20 PM
theneelster's Avatar
Technically you're filter needs to be submerged and you need to be laying on the throttle heavy to draw water into your engine...not going to be a problem unless it's a flood.
Old Jul 24, 2008 | 12:11 PM
Halfcent's Avatar
I'm old school
You guys both missed the point. I wasn't implying that his engine was going to explode. A wet filter is a dirty filter, meaning you are not going to get very good air flow through it. He was trying to say that with the splash guard off the car, the filter was getting more air. Not only is that not true, but in the rain, it will in fact get less.
Old Jul 26, 2008 | 01:55 AM
Jn2's Avatar
Jn2
i tried this on my old GMPP, got a CEL from it
Old Jul 26, 2008 | 02:35 PM
You must've done it wrong. Ive never heard of anyone getting a CEL from an intake, reversed your MAF sensor?
Old Jul 26, 2008 | 02:37 PM
silentd's Avatar
no almost all the 2.0 guys got a cel from an intake... its the increased air sets off a lean code.
i would put the splash shield back on, and IMO it looks cheap
Old Jul 26, 2008 | 03:07 PM
works fine on 2.2/2.4s
Old Jul 26, 2008 | 03:16 PM
bridfi's Avatar
lol
rice?
one local guy has his filter sticking through his grill
Old Jul 31, 2008 | 06:03 PM
ricetimo's Avatar
Hey I have a 2007 SS/SC and I want to Replace or Clean my CAI.
What is the best option as far as time and $$$$. I don't have my own garage to work in (i live in an apt) but i could work something out if necessary.
I was curious if just replacing the filter would be easier than cleaning it. Thoughts????
Thanks!!
Old Aug 19, 2008 | 10:56 AM
pat_07ss's Avatar
BULLETSSMOKE, what parts did you have to purchase in order to make this work?? (do you have the exact part numbers / or links to the exact parts on summitracing.com)
I removed my resonator this weekend, and am now hesitating between installing a pipe to collect cold air in front of my radiator up to the air box, or going your way for my CAI.
Old Aug 19, 2008 | 12:16 PM
http://store.summitracing.com/egnsea...8041&D=-118041
go there, you need one 45 degree elbow and one straight pipe, i got the 3 inch stainless steel ones. and then you will need an intake coupler for whatever size piping you get from http://store.summitracing.com/egnsea...00+-166081+115 and then you just attach the air filter to the end of that
Old Aug 19, 2008 | 12:26 PM
rrutter81's Avatar
more useful than the trunk-fail-mod
Old Aug 19, 2008 | 02:32 PM
lol, not mine!
Old Sep 10, 2008 | 11:04 PM
chevy cobalt 08's Avatar
man are you sure thats correct? Cause I just did mine and it barely fit.... Are you sure its one elbow and not 2? And 1 straight pipe and not 2? Cause it looks like you got 2 elbows and 2 straight pipes. If not that then you sure it's 45 degree elbow?
Old Sep 10, 2008 | 11:17 PM
ill go take a look real fast to make sure
ok the first piece is the GMPP pipe from the short ram that you bought, the one with the MAF in it, then there are 2 elbows and it looks like both are 22 degrees. then there is 1 straight pipe after the 2nd elbow and then the air filter attaches to that. sorry for the confusion
Last edited by BULLETSSMOKE; Sep 10, 2008 at 11:17 PM. Reason: Automerged Doublepost
Old Sep 10, 2008 | 11:18 PM
So I need one more elbow then. Well one is 45 so i guess i need a 22 then? Thanks for clearing that up! No wonder I felt like I was wrestling an alligator
Old Sep 10, 2008 | 11:23 PM
you do have to still wrestle it a little bit to get it in the right spot, there are like 2 sweet spots that it likes lol.
Old Sep 10, 2008 | 11:31 PM
lol, if you look at the pics I posted (pics and vids forum) It looks like stretched it or something lmao. I had to use the gmpp filter cause my other one was pushing the fender wall so far back the wheel would hit it on the slightest bump.
Actually you gotta have 45 and 22 it makes more sense than two 22's. Two 22's is 44 degrees but 22 and 45 is 67 degrees hence more bend. I only have one 45 and i had a big struggle. So then you HAVE to have 45 and 22. If that made any sense at all.. lmao
Old Sep 11, 2008 | 12:23 AM
well show me how it goes with a 45 and 22, i have 2 22's and works fine but maybe a 45 and 22 is better
Old Sep 11, 2008 | 12:26 AM
leviticus88's Avatar
2 years and 40000 miles and no cel on my intake, ss/sc
Old Sep 11, 2008 | 12:36 AM
Greased's Avatar
you must like cleaning your MAF sensor. cuz its gonna run like **** when that exposd filter starts sucking **** up.
oh yeah. thats right. you guys know everything.
nvm. i guess my personal experience was just... wrong. must have imagine my car bucking and almost dying on the highway.
just ta letcha know you will be able to get away w/ this longer than someone w/ forced induction but you should know that the dirtier your maf gets the less air it reads and the more your car will lean out. and once your in open loop ***** gonna start getting bad
Old Sep 11, 2008 | 04:02 AM
But that don't make sense then... oh I don't know... we'll just have to find out when I get a 22
Old Sep 11, 2008 | 08:51 AM
this is just like every other cold air intake in existence for the cobalt, that post was helpful but not really necessary. we all know the possibilities of hydrolocking and sucking up dirty ****. and yeah i do clean my intake and MAF about as often as i get an oil change.
