How to: Make a perfect 50/50 meth mix
Found the info a while back from a Snow perf rep. Pretty simple, though sure it could help a few.
Needed: 1 Gallon of blue -20 washer fluid (no additives) 3 12oz bottles of yellow bottle Heat. spare jug and marker. https://i263.photobucket.com/albums/...bucket/mth.jpg Start by marking the top of the fluid on the jug with a marker. https://i263.photobucket.com/albums/...ucket/mhht.jpg Pour about half of the jug into a clean container or jug. https://i263.photobucket.com/albums/...bucket/mef.jpg Add your three bottles of Heet Then pour your fluid set aside back into the jug until it is even with the jug you drew. Put the extra fluid in your washer tank and there you go a perfect 50/50 mix. https://i263.photobucket.com/albums/.../Methmixed.jpg |
easiest how to ever thanks lol
Why not just buy a jug of 99.9% Ethal alcohol, pour half in ur tank, fill other half with water, perfect 50/50 mix, much easier to remember. Can be found in paint section or some automotive sections of hardware store
Anyone have any luck with this? Is it really a good mix?
This ^^^
yeah works for me
Yeah, Came from a Snow performance rep. If you want more "meth" you can make it with 4 or 5 bottles of heet. Just keep the mixture that you're tuned on.
Easier way.. buy methanol from race shop. Add 1 gal to 2 gal jug. Add 1 gal distilled water. Can't really get easier than that. 75/25 works better
Originally Posted by tomj77
(Post 6512661)
It's calculated by weight, not volume... |
Originally Posted by BriantheLion26
(Post 6646104)
There is a guy down the street that makes meth, his stuff must be pretty good cause he has fires and small explosions in his garage regularly.
Originally Posted by iAaron
(Post 6645592)
Darrell Cox Racing did my car and it's what they recommend with the tune. |
Originally Posted by Perfect.disguise
(Post 6646113)
If you're eye balling it and guessing half, it's not a 50/50 mix. Even if you measured it out to be the same it would not be a perfect 50/50 mix..
It's calculated by weight, not volume... http://img52.imageshack.us/img52/859/img2421qx.jpg |
(Post 6647504)
Saved for future
I'm out of meth and closest place that carrys it is closed. gonna go to autozone and buy this stuff.
what percent water/meth is -20 fluid? what does the heet do? raise the octane? :lol: don't add any water? |
(Post 6894461)
what percent water/meth is -20 fluid? what does the heet do? raise the octane? :lol: don't add any water? I have a 50/50 Mix with Heet! |
so is it like 50/50 heet/fluid?
(Post 6894506)
yup
cool i did this last night. worked out nice, car hasn't blown yet so i guess were good
oh and the total was only around $8.50 so its actually cheaper than the 'boost juice' i was buying for $10 a gallon lol |
