Appearance: How-To: Paint your drums
Old Jul 12, 2007 | 09:47 PM
BlackLS's Avatar
This how to will explain how to paint the drums on a base Balt or any car for that matter.
1. So your drums look like this all rusty and you want them to look nice and clean this is all you have to do.
[IMG][/IMG]
2. To do this you will need all the tools pictured below (Which are a hammer, flat screw driver, some kind of cutters, a lug nut wrench, a torque wrench and what ever socket is required for your lugnuts which are 3/4" if they are stock ones, a corded drill and some kind of wheel designed to remove rust like a wire wheel or what I used which is a wheel that almost looks like plastic and it is kinda webby looking but I'm not sure what it is called, and any kind of cleaner or brake cleaner, and your choice of duplicolor caliper spray paint) as well as 2 jacks or a jack and jack stands.
[IMG]
3. Start by jacking up the car and removing the wheel. If you have never had the drums off before you will see to metal clips over the wheel studs that look like washers. Take your flat screwdriver and stick it behind them and pry them out far enough that you can cut them off.
[IMG][/IMG]
4. Once you have removed the two clips you can remove the drum itself. First of all make sure the e-brake is off or you will be hammering away forever and it wont come off Now just take a hammer (a mini sledge works best) and beat the hell out of the drum in between the wheel studs. It works best when you focus on just hiting at one spot. After enough shots it will pop loose and you will be able to slide it off.
5. After you get the drum off take your drill and some kind of wheel designed to remove rust and go to town on it making sure to remove all the rust down to bare metal.
[IMG]
6. Once it is bare metal spray id down with some kind of cleaner and then take some duplicolor caliper spray paint and spray light coats on it until you are happy with the way it looks.
7. After it is painted allow it to dry for a couple hours (atleast 3). Once it is dry just slide it back on the lug bolts.
[IMG]
8. Now just put your wheels back on and torque them properly and you are all set
Here is the finished product: [IMG][/IMG]
[IMG]
One can of paint did 4 calipers with 2 coats each and the can is still about a 3rd of theway full.
This was my first how-to so let me know what you all think of it.
Last edited by TommyP; Oct 3, 2012 at 10:32 AM. Reason: Fixed some stuff that was suggested.
Old Jul 13, 2007 | 02:59 AM
HunterKiller89's Avatar
as far as a first how to...id describe the tools more...like what sizes everything is and whatnot...what kind of "rust removing disk" you used...but its a very good how to otherwise
congrats and gj
Old Jul 13, 2007 | 11:28 PM
BlackLS's Avatar
congrats and gj
Thanks for the compliment and i did add some about what tools were needed like you suggested
+rep for you for the good advice
Old Jul 13, 2007 | 11:36 PM
badassgixxer05's Avatar
i would have clear coated them with high temp paint too so the caliper paint doesnt come off after time..
Old Jul 15, 2007 | 12:12 AM
shawn672's Avatar
wow those do look a lot nicer!
I could never figure out why GM would sell a car with rusty brake drums on it? Brand new car, rusty brake drums...hmmm I see it all the time at various dealerships
Old Jul 16, 2007 | 02:51 AM
Infernokron's Avatar
Something else you might add to the tool description: The lug nuts are also a 19mm (assuming stock), and the torque for them is 100 ft/lbs.
Great write up, and thanks for not painting them red .
Old Mar 19, 2008 | 03:31 AM
Black08SSTC's Avatar
did you put the 2 clips back on the drum after you took them off and if not what did they do??
Old Mar 19, 2008 | 08:09 PM
CobaltLT's Avatar
The clips aren't needed, they just are used during the manufacturing of the car so the drum/rotor doesn't slip off the studs going down the production line.
Old Mar 24, 2008 | 03:36 AM
Jn2's Avatar
Jn2
good write up, im acutally going to just use the kit that comes in a brush, makes doin it easier, dont have to take anything off
Old Mar 24, 2008 | 03:43 AM
Hockeyman's Avatar
glad you painted them black and not some stupid bright color...looks good man, a lot better than rust.
Old Mar 24, 2008 | 09:57 PM
Sharpie's Avatar
Can someone please circle where i hit to get the drum off?
Old Mar 24, 2008 | 10:03 PM
Switt23's Avatar
Just hit it hard in between the wheel studs. They aren't pressed on, so hitting them should eventually 'knock' them loose.
Old Apr 15, 2008 | 09:20 AM
plasticplant's Avatar
Nice write up. Could I just use sandpaper to get the rust off?
Old Apr 30, 2008 | 03:49 PM
Sharpie's Avatar
Yes but it will take a while, just get a wire brush and use that.
Old May 2, 2008 | 03:51 PM
VzJoe's Avatar
Or a Wire brush bit attached to your drill = even faster.
Old Jun 26, 2008 | 11:33 AM
ilovecars's Avatar
im sorry im slow but where do you hit the drum?
Old Jun 26, 2008 | 11:58 PM
ilovecars's Avatar
Old Jun 28, 2008 | 06:38 PM
Sharpie's Avatar
Originally Posted by ilovecars
Just hit it where ever just make sure not to hit the studs. Also mine took a few good swings to get loose so dont be shy to hit it hard.
Old Jun 28, 2008 | 08:56 PM
ilovecars's Avatar
couldnt i just pry it off?
Old Jun 29, 2008 | 01:24 PM
wbrevels's Avatar
if installing new rims it is a good idea to take the clips off because it can offset the wheels
Old Jun 29, 2008 | 03:12 PM
Sharpie's Avatar
Not really just take a hammer and a screw driver and just start hitting it.
Old Jul 11, 2008 | 06:27 PM
wbrevels's Avatar
my car only had 2k miles and no hammer was needed, they slide right off
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 26, 2015 12:57 AM
