2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
#151
However, i will actually reccomend if you plan on making more power in the future, that you get some 60lbers now.
#152
Alright thanks all! But since im running the 2.2 now and vince is the only tune available right now..do you think he can tune for the 60's or no? I think i should just go with the 42/5's for now because wouldnt i need alot more mods to even touch 250?
#154
Alright but you guys were saying the idle will start getting weird if i go with the 60's, i have to keep in mind this will be my daily driver and this is my only car so i need it pretty reliable.
#166
So I've got everything i need to supercharge mine just wonderin about the AC.. i know the SC belt has one more rib, I've got an lsj alternator, and a lightweight crank pulley with enough groves, and the idler pullye and tensioner off of an SS, but then there is the AC compressor pulley. what did you do about this?
#168
Anywhere between $2000-$2800.....
#170
as far as price. all the hard parts were $1300 used. figure $300 for a tune/piggyback and a couple hundred for a wideband. Everything else is optional. You can run this setup on stock exhaust even...it just wont perform nearly as well...so i reccomend an upgrade
#172
you need 42s or 60s
correct me if i'm wrong casey, but it says plug in play on their website.
i asked another member on here and he said no other wiring was needed. lemme know
or explain why you took a new harness and and old one haha.
#173
https://www.zzperformance.com/cobalt...=516&catid=144
you need 42s or 60s
you need 42s or 60s
I can grab pictures of both harnesses if that will help. But regardless, since no one makes a aftermarket wiring harness for the L61, you will have to make your own like I have done.
#174
dammnn
that sucks.
you need to move to austin to help with this stuff !
i'll try and look at the pics and see if i can figure it out.
i've been really sick again, so nothing makes much sense haha.
that sucks.
