Install Aftermarket Head Unit 06 LS(Lots O Pics)
I searched around but didn't find an exact link so I decided to make one, but found great info on the site. I have an 06 LS so im not sure if it will work with the other models but it's worth a shot.
TOOLS NEEDED: 9/16 Ractchet Butt Connectors(or Electrical Tape) Crimper GM wiring harness 93 or higher(no pic of box but got it at walmart) 05(06) Cobalt Dash Install Kit (no pic but got it at brandsmart usa) Screwdriver(phillps or star) Needlenose pliers First:When you get the wiring harness it needs to be repined. Take your needle nose pliers and one by one gently but firmly remove ALL the pins from the grey harness. Cut away all the extensions from the grey harness to the blue harness, you won't need the blue harness part. Then insert the pins in this order:(originally posted by theboy16 thnks) a1- white/black a2- white a3- purple/black a4- purple a5- green/black a6- green a7- grey a8- grey/black a9- blue/white a10- orange a11- empty a12- black b1- yellow b2-b12 empty Second:Remove paneling around stock radio, remember to take the lower panel under the steering wheel to take the trim out on the left and open the glove box to take the trim on the right, they all just pop off, but be careful. Remove the screws around the stock radio [IMG]http://i217.photobucket.com/albums/c...y/IMAG0052.jpg[/IMG] Remove the stock radio [IMG]http://i217.photobucket.com/albums/c...y/IMAG0053.jpg[/IMG] Here are some pics of the wiring harness. this is the A Side [IMG]http://i217.photobucket.com/albums/c...y/IMAG0054.jpg [/IMG] And The B Side [IMG]http://i217.photobucket.com/albums/c...y/IMAG0055.jpg[/IMG] Next you must crimp the wires from the GM harness to the aftermarket radio harness, follow your colors! ATTENTION!!! The GM harness does not have a 12V switch so you can tap into a fuse or a wire so that your radio turns on when you turn your key. I DID NOT WANT TO TAP INTO ANY STOCK WIRING so i sliced the RED wire with the YELLOW CONSTANT wire. This means my radio DOES NOT TURN OFF WHEN MY KEY COMES OUT! But i like it that way. i always remember to take my radio out. Here are the harnesses crimped [IMG]http://i217.photobucket.com/albums/c...y/IMAG0056.jpg[/IMG] http://i217.photobucket.com/albums/c...y/IMAG0057.jpg I finished it off with eletrical tape, so it stays all together. [IMG]http://i217.photobucket.com/albums/c...y/IMAG0058.jpg[/IMG] Next put your aftermarket radio in the dash install kit, follow the kit's directions. [IMG]http://i217.photobucket.com/albums/c...y/IMAG0059.jpg [/IMG] [IMG]http://i217.photobucket.com/albums/c...y/IMAG0060.jpg[/IMG] [IMG]http://i217.photobucket.com/albums/c...y/IMAG0061.jpg[/IMG] Next plug your aftermarket harness into the aftermarket radio [IMG]http://i217.photobucket.com/albums/c...y/IMAG0062.jpg[/IMG] And plug it in where your stock radio was [IMG]http://i217.photobucket.com/albums/c...y/IMAG0063.jpg[/IMG] then install your aftermarket radio back into the empty slot, This one was actually a little longer than clearance allowed so it sticks out a bit. [IMG]http://i217.photobucket.com/albums/c...y/IMAG0064.jpg[/IMG] FINISHED RESULT!!! [IMG]http://i217.photobucket.com/albums/c...y/IMAG0065.jpg[/IMG] AND THERE YOU GO!!! I LOST NO DOOR CHIMES WHAT SO EVER except of course when you open your door and the radio shuts off because mine stays on. But this way if I want to install the stock back it's really simple. NO $100 harness!!!!! Thanks, comments and questions or mistakes just let me know. This is my Fist How To!!! thanks again |
approved
Nice job, ill keep this close just in case when i need it.
later |
Originally Posted by RollOver360
(Post 1695930)
later |
nice,how to
so you just cant take the panel around the stereo out,you have to take all panels out,under steering wheel,etc? thank you |
Originally Posted by jimmy1956
(Post 1706055)
nice,how to
so you just cant take the panel around the stereo out,you have to take all panels out,under steering wheel,etc? thank you :cssNET: |
the ls base model doesnt need the 100 dollar harness, the others do if they want to retain factory warning chimes
Great tutorial I just have two questions. Is there a way I could wire it so that it would turn off and on when the car does so? Can I also get it to run off the capacitor till the car automatically shuts it off or when I open the door?
FYI a good fuse to tap for the red wire is the sunroof fuse (best) or windshield wiper fuse
Originally Posted by Blue_Balt
(Post 1714631)
Second, because i didn't want to mess with any stock wiring i ran my red wire through the constant wire so my radio stays on constantly so I don't know. sorry bud |
So with the whole 12v situation, would it make sense why my aftermarket deck isn't turning on?
Originally Posted by Sharpie
(Post 1716049)
Nice how too, :thumb:
nice, you have a similar deck to mine, i have the KDC-MP2035, mine straigh forward plug and play, i plug up the harness's, and connected the red power wire to the wiper fuse under the dash, and that was it, work fine, but nice how too
ps-crutchfield give you everything you need with the install free when you buy a deck from them :D along with instructions, that are vehicle specific |
Originally Posted by balmung892003
(Post 1719203)
subscribed
Okay I got my deck to power one but i have no sound, all my wires are hooked up correctly. Now I talked to a mechanic and he said something about the stock amp and I have to splice into it... Does anyone know how to?
So where does the brown wire go? It is the ground right? i thought it went in to the chassis, but u have it connected to the harness??im doing my install tomm just want to make sure i do not want to fry nething up haha
would this work with a ss/sc?
I've spliced the red with the yellow constant but my head unit still won't turn on. Any ideas, maybe my head unit is dead, is there any way to check if its dead?
Originally Posted by tigur33
(Post 1790165)
if red and yellow are getting 12v and black is grounded then the hu should work (along with fuse intact like 88 said)... test it on a 12v battery and see what happens
Thanks I figured it out why it wouldn't turn on. The antenna adapter was loose, had to get in there with a flat head screw driver to open it up a bit to fit tightly in there :confused::confused::confused:
Originally Posted by hg_5
(Post 1790049)
hey i got this done at a local audio shop and the guy
couldnt get the radio to turn on when i turn the key to ACC it only powers when i turn the whole car on! he tap the airbagfuse with the red cable. any one know what ican do to fix the problem so i can listen to my music with the car off? thanks in advance |
