Install Powell F35 Stage2 Mounts
For detailed pictures to go along with these instructions refer to John's install thread in the drivetrain section. https://www.cobaltss.net/forums/driv...sj-lnf-253153/
I do not reccomend these instructions for impatient people. This needs to be done very carefully as the THREE mounts will be loosened/uninstalled at one point. thanks to recklessactn for the use of his "before install" pictures as i didn't think about taking any untill i already had installed them. Use a 2x4 inbetween the jacks and engine. By the way, don't complain about not having a lift or anything, i did all this with the car just up on ramps. I also had the downpipe and catback removed so i could install the hahn exhaust, but having the downpipe removed gave me an ungodly amount of space to move around in, if you can remove the downpipe for this, i strongly reccomend it. "tighten(ed) down" means....no play at all. "rear trans bracket(18mm)"VVVV https://www.cobaltss.net/gallery/fil...ct0014crop.jpg "REAR THREE MOUNT TO SUBFRAME BOLTS(15mm)"VVVV https://www.cobaltss.net/gallery/fil...ct0012crop.jpg FRONT TRANS MOUNT BOLTS(18mm). LEFT=MOUNT TO SUBFRAME. MIDDLE&RIGHT=MOUNT TO TRANS https://www.cobaltss.net/gallery/fil...ct0009crop.jpg step1: Place hydrolic jack under trans. step2: Place floor jack under oil pan(as close to pass. side as possible) step3: Loosen the three bolts on the top of the passenger side upper engine mount BUT DO NOT TAKE THEM OUT!!!! LEAVE THEM THREADED!!!! ...just loosen them to allow a little movement(about .250") step4: Remove front transmission mount via the three bolts step5: Remove the WHOLE rear transmission mount assembly(mount, heatshield/bracket) via the three bolts on the bottom of the mount and the three bolts on the mount to trans bracket. LEAVE THE BOLT THAT GOES THROUGH THE MOUNT UNTIL IT IS ALL OFF THE CAR!!!! (it will all come out in one piece.....if it doesnt, you screwed up). once you can move it around, pull out the 02 electrical connections. its got a "christmastree type connection into the mount. step6: Seperate the mount and bracket via the main bolt through the mount step7: Reinstall bracket via the three bolts (WITHOUT THE MOUNT!!!) and tighten down. step8: Install rear trans mount via the three mount to subframe bolts and tighten down. step9: Install front trans mount via the two mount to trans bolts and leave loose. Install main bolt through the mount and start the thread it slightly, leave it loose as well. AT THIS POINT, BOTH OTTP MOUNTS SHOULD BE ON THE CAR. FRONT SHOULD HAVE ALL THREE BOLTS LOSSELY IN. REAR SHOULD HAVE THE BRACKET ATTATCHED TO THE TRANS AND THE MOUNT ATTACHED TO THE FRAME, BOTH OF WHICH SHOULD BE TIGHTENED DOWN.step10: (Extra set of hands is useful here) Using the hydrolic jack under the transmission, start to jack it upwards untill the bolt that connects the rear trans mount to the bracket will go through(this is a fairly good amount in terms of engine movement) AT THIS POINT, ALL BOLTS SHOULD BE ON THE CAR AND ALL THE WAY OR LOOSELY TIGHTENED step11: Tighten the three bolts on the upper motor mount back down all the way and remove the jack from under the oil pan step12: Tighten up ALL BOLTS on the front and rear trans mounts and remove the hydrolic jack SLOWLY, this is when everything will settle back down. step13: Go for a LIGHT!!! (DO NOT HIT BOOST, DO NOT HIT MORE THAN 3K RPMS) drive around the block and pull back up the ramps. Yhis will allow the bolts/mounts to do any final movement step14: Give everything a final tightening to trq specs. :cssNET: INSTALLED PICTURES http://i281.photobucket.com/albums/k...tSSSC009-1.jpg http://i281.photobucket.com/albums/k...tSSSC010-2.jpg http://i281.photobucket.com/albums/k...tSSSC006-3.jpg http://i281.photobucket.com/albums/k...tSSSC007-2.jpg http://i281.photobucket.com/albums/k...tSSSC011-1.jpg http://i281.photobucket.com/albums/k...tSSSC012-1.jpg http://i281.photobucket.com/albums/k...tSSSC013-1.jpg http://i281.photobucket.com/albums/k...tSSSC014-1.jpg |
click for later
bump for being approved
I put my stage1 mount and rear spacer in yesterday,took me 30min to do.When i start putting more power down,i will get the rear mount.I highly recommend them:twothumbs!
yea the stage1 isn't going to take took long but it is still a very nice improvement over stock
where's the install pics of the new mounts in place?
for the rear mount, i didnt loosen the bracket, i just left the bottom 3 bolts really loose and put the bolt through the bushing first and used the 3 to line it back up.
Originally Posted by ralliartist
(Post 3749280)
pictures uploading. i took more of the rear one cause its a lot easier to get good angles of the front so i don't need as many for that EDIT: pictures moved to first post so i post up pictures and everyone leaves....:lol: |
I thought they were stock mounts with spherical bushings and a spacer; thats why there is a core on the stockers?
The machined billet looks nice. |
bookmarked, looks like this will be a pain in the ass, but then again trying to mod anything on this car is
i think the ones youre talking about are the older ones. or the stage1 mounts
Originally Posted by Rodimus_Prime
(Post 3749905)
i'll do them for you if you want me to. you can pay me with the tvs ya got there ;) |
haha, i dont think its hard enough to warrant a 6 hour drive
I installed mine in about an hour (on ground with jack stands) and I'd say its about a 2 out of 10 on the difficulty scale. Not a single cuss word used! No swearing= easy! in my book.
Good stuff man. Sub'd for later
quick question as mine vibrate bad because i did'nt let them settle and instead just torqued them to spec but when you say "tightened" then took them for a drive do you have an approximate ft lbs you tightened them 2?
i just tightened them enough to where they wouldn't fall out. but were still about to be "vibrated" so to speak, into place. but by no means should you leave any threads exposed hahah
Originally Posted by turbaltss
(Post 3752259)
How much is the trq specs for all the bolts
I have a pair of questions in regards to this install. Keep in mind, I am applying these instructions simply to installing just the stock mounts right now.
1) Would doing the install with the car up on jackstands make these instructions differ from having it up on ramps? 2) Does anyone think that improperly installing these mounts, or any tranny mounts for that matter create an excessive amount of false knock? Thanks in Advance.
Originally Posted by efrommel
(Post 3812538)
so a couple of questiond for me. did anyone ever find the correct torque specs for the mounts. and i ordered the ttr engine mount and tranny bushing. will i be following the same procedure as you did hear? i think i would, but didn't think it would hurt to ask either.but if anyone knows, what do i have to do to press out the bearings.? i would think just press one out and press one in. but im not sure and would like advice from a person who has done this before.
sub'd for later
this helped a lot gonna put mine in today got the stage 2 mounts from josh (ottp).
Thanks for the how-to. Really helped me out today.
Here are some quick torque specs:
Originally Posted by qwikredline
(Post 4016556)
Originally Posted by TimmysMonteCarlo
(Post 4014522)
Front trans mount
mount to trans=66lb ft trough bolt = 74lb ft Rear tran mount mount to frame=44lb ft through bolt= 74 lb ft These are from GM wheel hop kit install instructions. |
i just got my stage 2 mounts. ill be doing this sunday mayb
sub.
I have the stage 1 mount and will be installing it in the spring :) |
Installation question
http://img38.imageshack.us/img38/295...0304162331.jpg
Ok so i ordered Hypersingle and Stage 2 rotated mounts One of the mounts has spacers/bushings zip tied to them There were two others in a plastic ziploc bag. Are these for the front trans mount? woa, sorry for the large cameraphone pic |
