All Engines: Oil Change How-To with picture!
#277
nope....but what I do is keep a record of all the maintenance I do including date and mileage and receipts...but it's just overkill on my part, in case I sell the car at some point down the road I can show how well it's maintained
#279
anyone know how many miles you can go with mobil 1. I have gone 5 thousand miles and i show 24% on my computer and wondering if i should do one or wait until the percentage goes down a little more.
#282
fixed
an easy way to tell is to check the basestock group, anything short of pure PAO/ester (group IV+) is not a true synthetic
I'm going to post this for the millionth time and probably get flamed for it, but, your precious Mobil 1 isn't a true synthetic anymore. Its a synthetic blend of group III (highly refined mineral oil) with a small amount of group IV (pure synthetic)
#283
So what is mobil 1 out everywhere as i went to 3 walmarts today and napa an they were all out of state for mobil 1 as they said mobil 1 is behind because of them being shutdown over the summer. So i had no choice but to go with castro sythenic and napa gold filter. What do you guys think of castro??? My oil change is done and another easy oil change. I see the price went up to for mobil 1 at walmart from $23 to $26.50 now.
#285
i got syntec 5w-30. Should i go with the 0w30 amsoil or back to mobil 1 on my next oil change.
#286
Filter list
Here is a culmination of research I've done on filter brand part numbers and info
- AC Delco: PF457G (PF458G Includes replacement cap and O-ring) (Revised with more cap teeth from old PF456G) (Hengst rebrand?)
- AutoX: PE-036
- Beck/Arnley: 041-0810
- Bosch: 72215
- CarQuest: 84082 (WIX rabrand?) (Comes with O-ring for the cap) (Nearly identicle design to Hengst)
- Fram: CH9018 (and extra guard version)
- FULL: (Hengst rebrand?)
- GM: 90537280, 9194746, 21018801, 22685727, 93171212 (Saturn 22685725)
- Hastings: LF548 / HALF548 (Odd zig-zag filter element pattern?)
- Hengst: E630H
- K&N: HP-7000
- Knecht/Mahle: OX258DOEKO
- Mann and Hummel: Hu69/1
- NAPA Gold: 7082 (WIX rebrand?)
- Purolator: PureONE PL15436 (2 pack part#?) (PremiumPLUS: L15436)
- STP: 9018R
- SuperTech: ST9018 (nearly identicle design to Fram)
- WIX: 57082
It appears the Hengst is the real OE part. I have found Pics on other forums where the AC Delco filter is actually a Hengst E630H02 (labeled on the filter).
Amsoil doesn't appear to make one yet so they refer to the WIX filter.
Hope this might help. Let me know if you see anything I might have mixed up.
- AutoX: PE-036
- Bosch: 72215
- Hengst: E630H
- K&N: HP-7000
- STP: 9018R
- WIX: 57082
#287
Just changed my oil using your write-up. Thank you very much. I saved a bundle of money from it I'm sure. I'm pretty impressed with myself too although it was just an oil change. Thank you!
#288
The LNF turbo charged Cobalt takes 5 1/2 quarts. Not 6 or 6.5. You definitely do not want to over fill your engine by 1 1/2 quarts!!!! You run the risk of over pressurizing the crankcase. Check online. I just changed mine and it checked it after 5 qts., it needed 1/2 qt. more to be full on the dipstick.. I even drove it around to fill the filter but it was it, it was full on the dipstick. Maybe the supercharged car requires more but not the turbo car. Be careful. I bought 7 qts and was ready to pour in 6 and then check. Luckily I checked before doing that.
#291
i haven't used it in my own vehicle but some of my customer do use it in theirs. one is in a kia rio and they do about 8000-10000 kms on it and it actually seems to be in pretty good shape when it get's drained. one customer uses it in his 89 honda... lol. but only goes 6000 kms on it. they seems to like it. i have no bashings of it yet...
#296
When I was recently checking oil I got a small piece of tissue(about a 1/4 the size of a dime) in the oil check tube, will that get by the filter and should I get my oil changed for reassurance?
#298
Hey everyone,
Today i picked up some 0w30 mobil 1 at walmart for $26.00. Has anyone used the 0w30 yet. It shows better fuel mileage than the 5w30.
Syntec 5w30 oil sucks. Since they didnt have mobil 1 last time i had to get this and hate it. Now im back to mobil 1 and im sure my car will run better.
Josh
Josh
#300
Does anyone have pics of the oil passageways in the filter housing on the engine? I am curious how the oil flows. The o-ring on the base of the filter seems to do nothing, but I haven't looked at the housing yet.
