Spinner's LC1 Installation Guide with Pics! (no 56k)
Since there were no good guides on how to do this, and since I was tackling it blind, I made a small guide to help people with installing a wideband on our cars. Complete with pictures.
http://www.stang.cc/tmcagallery/d/20...0+_Medium_.JPG So, before we begin: Time required: 1-2 hours Tools Required --------------------------- Soldering Iron (4) Round terminal ends Electrical Tape (Optional) Shrink Wrap Zip ties (At least 6) Ramps, a jack and jackstands, or ab]B lift. A buddy (recommended) 10mm Socket Small cutters Large Flat screwdriver to remove fuse panel Fuse Puller (from your fuse box under your hood) --------------------------- Step One: The wiring Lay out your LC1 wideband, it should have seven wires coming out of it. The brown/yellow wires are your wideband outputs, we will not need those for now. Put them aside. What we're focusing on first are the Blue, white, green, and black wires. My iron is a small butane soldering iron, and an easy button. Gotta have an easy button. http://www.stang.cc/tmcagallery/d/20...2+_Medium_.JPG Take the blue, white, and green wires and slide a round terminal over the end of the wire. Solder the terminal to the wire with a soldering iron. Once soldered, set them aside, they should looks like below. http://www.stang.cc/tmcagallery/d/20...4+_Medium_.JPG Now, take the black wire, solder the positive end of your LED light to the black wire. Once cooled, either heatshrink, or electrical tape off this connection so no metal is showing. Now, solder the black end of your LED to one of the ends on your push-button switch. Again, shrinkwrap or tape this connection. Finally, you put a round terminal end on the only open end of the switch. It should look like below. Note: If you wanted the led/switch to be visible, you'd have to set them in the panel you wanted them to be in before soldering. Since they aren't used as part of the wideband's regular function (only calibration) I chose to have them hidden inside my panel with the rest of the wiring. http://www.stang.cc/tmcagallery/d/20...6+_Medium_.JPG Great, you've now got all four grounds with terminals on them. Time to move on to the sensor itself. http://www.stang.cc/tmcagallery/d/20...9+_Medium_.JPG Find the O2 plug in your exhaust, it should look something like this. Remove the plug, and screw in your sensor. Tighten it enough to crush the crush washers, it doesnt need to be hercules tight. http://www.stang.cc/tmcagallery/d/20...1+_Medium_.JPG Attach sensor to LC1 module, and zip-tie LC1 module into place. This is the location I used. It sits ~1" above the frame, so there is no chance of damaging the wiring or the module. http://www.stang.cc/tmcagallery/d/20...8+_Medium_.JPG And a better view of the mounting. I used 3 zip-ties to make sure it wasnt moving anywhere. http://www.stang.cc/tmcagallery/d/20...9+_Medium_.JPG Now, take your wiring coming from the LC1 harness, and snake it behind the hard lines shown here. There is plenty of space. I highlighted where the wires are in the picture. http://www.stang.cc/tmcagallery/d/20...0+_Medium_.JPG Once you get this far, just let the wiring hang. We need to go inside the car before we can go any farther. Open your door, and look behind your pedals. Behind the clutch, you will see a large rubber grommet plug, with some wiring coming out of it. Pull on an edge of the grommet (this may take some force) and pull the grommet into your car. Cut a small notch in the grommet plug for your wiring (not shown in pics) http://www.stang.cc/tmcagallery/d/20...3+_Medium_.JPG Okay, now return to being beneath your car. If you have a buddy, have him stay inside the car, so he can grab the wires you're about to snake through the hole you just created by moving that grommet. Snake the wires into the car. The hole is next to the steering shaft, that makes it easy to find. http://www.stang.cc/tmcagallery/d/20...7+_Medium_.JPG Now have your buddy pull the wires through, or do it yourself, enough to remove all the slack on the wires so there's nothing loose in your engine bay. http://www.stang.cc/tmcagallery/d/20...4+_Medium_.JPG Once the majority of the slack is removed, zip-tie the wiring to the hard lines in the engine bay so there is no chance of them getting stuck to the steering shaft http://www.stang.cc/tmcagallery/d/20...2+_Medium_.JPG Great! The underhood part of this installation is OVER! Its all gravy now. Open your drivers door, and to the right of your pedals is a fuse panel. Use a big flathead screwdriver to remove the plastic screw in the rear, and remove the panel. Behind it is a fusebox, and two 10mm nuts. Use your 10mm socket to remove the two nuts. http://www.stang.cc/tmcagallery/d/20...3+_Medium_.JPG Now, once nuts are removed, place blue wire terminal end over top stud. Put nut on, and tighten. Now place the white, green, and black wires over the bottom stud, and tighten the nut. It should now look like this. http://www.stang.cc/tmcagallery/d/20...4+_Medium_.JPG Now, remove the 15a fuse shown in the picture below with the fuse puller from your main fuse box. (It's a small white piece) Cut the hard end off of your red wire with some cutters, and strip the wire so you have some loose wire strands showing. place the strands over the lower hole where the fuse pushes in; and use the fuse holder to push the fuse in over the wire. This should hold the wire into place. Now you have a switched power source. http://www.stang.cc/tmcagallery/d/20...5+_Medium_.JPG Final Step Hit your easy button. "That was easy!" You are DONE! Connect your wideband outs to whatever you wish (I didnt, I juse use the digital out) if needed, and replace fuse panel with all wiring behind it. Replace grommet back into hole. If you run the wires out of the grommet hole and under the carpeting behind the pedals, they will be invisible in your interior. Follow the LC1 calibration instructions, and start monitoring! |
This is a great how to, so it's moved to the how to section.
Awesome :twothumbs
Is it ok to leave the wideband sensor in all the time and just use the analog output to act as the stock sensor?
<-----A/F Wideband noob |
great post!!!!very usefull
Originally Posted by CHARGDSS
(Post 725004)
Very Nice!
i just got the AEM wideband gauge. it says that the wires black is for ground and white for analog output and blue for serial output. is the wires you hooked up for ground the same?? im a little new to widebands
What fuse did you use? I'd go out and look, but my car is currently at my girlfriends house, up on jackstands, waiting for me to finish what I've been doing all weekend.
Nicely done. I have to do this soon so thank you. :twothumbs
is the 02 bung already there or does that need to be added by ashop?
Nice, will be doing this to my car soon! I don't know about just sticking the wire under a fuse. I know it works, but its a little ghetto for my taste. Great write-up though!!
Originally Posted by SKDR112888
(Post 975680)
how much will a shop charge?
$15, maybe a little more for welding a bung...
I used a 'add a fuse' instead, they run $10. |
sorry for the lame question but wat the fuk is a wideband lol
yeah thanks that cleared everything up
:redx:
^ Going to be installing my wideband this weekend, or at least I hope. Any tips and those pics no longer are up or something. *sob* |
:redx:
Originally Posted by ItalianJoe1
(Post 975701)
The pictures are not working. Do you have a link for the pictures?
Also, were there any settings you needed to change in logworks from default? Believe it or not, my laptop doesn't have a serial jack. It's pretty new. So I will have to borrow a friends to get logworks up an drunning to change any settings? |
:redx: :redx: :redx:
I NEED PICS! lol I've had my wideband sitting my the cobalt in the back seat since I bought it, and I really wanna install the damn thing. Any mods know what happened to the pics? |
i would also love to have the pictures...
Its actually easier than it seems. I have it installed, maybe I can take some pics of the finished product.
tagged for later. pics would be superb.
