How to Camshaft position sensor 06 SS/SC
I saw a guide posted but it was for VVT cars and im told my 06 2.0 SS/SC is a non VVT car(not sure what that means). If anyone can help me it would be great I have to get this done this weekend as I work 12 hr shifts Monday thru Saturday and this is the first and last Saturday I will have off for a very long time. Thanks in advance for any help and if im just dumb and missed the HowTo that is already posted please smack my peepee and point me in the right direction. Thanks again guys.
bring #4 cylinder to TDC on compression. align the groove in the hex with the raised boss on the external housing, check with Mr.Belvedere for a good picture of this.
stick it in, make sure it doesnt rotate as you stick it in.
If you are unable to deal with it moving as you stick it in, then remove the magnetic pickup sensor, and then mount the cps, and replace the magnetic sensor afterwards. Its easier for the hex shaft to not move with the magnetic sensor out of the housing.
BUT its a pita to put the sensor back in afterwards as there is not a lot of room.
good luck.,
any questions pm Mr. Belvedere.
good luck.,
Sl0wbaltSS
Nov 21, 2018 11:11 PM
