How to put in HID
Okay so I need your help. I got my hubby xentec hid kit for his Spyder projector lights and I am installing them so I need I bit of help..... I have almost everything done but the last two freaking wires the one is the pos the other neg where do they go?!! Need to know asap
All you gotta do is run the neg wire to a grounded bolt. Most commonly used one is the first bolt on the fender. The pos wire gets run to the post on the fuse box. That post can be unscrewed with a 10mm socket or wrench. Put the wire under that post, then screw it back on.
