Go Back  Cobalt SS Network > Community > The Lounge
03-20-19 Why is it Only Wednesday Workchat >
The Lounge Off Topic PG-13. Introductions, cars, movies, work, relationships, etc.
Old 03-20-2019, 07:53 AM
royce777's Avatar
Liked 122 Times in 102 Posts
Only half way there? slow week
royce777 is offline
Old 03-20-2019, 07:57 AM
Liked 376 Times in 333 Posts
Seems like a long week for me too, feels like the weekend was so far in the past.
ECaulk is offline
Old 03-20-2019, 08:04 AM
Liked 438 Times in 412 Posts
In
Snail_SS is online now
Old 03-20-2019, 08:43 AM
Liked 140 Times in 136 Posts
Anyone have any experience with Chevy sequential central port injection and converting them to multi-port fuel injection? I have a 1998 Chevy 1500 with the 4.3L and am having some intermittent issues and wonder if the SCPI assembly is to blame as they are known to be problematic and my truck has 216,000 miles on it. Lately I have been getting an intermittent lean code and also a cylinder 5 misfire. The lean code happens while cruising low load in 5th gear. I have checked o2 sensor function and they seem fine and I don't think it's vacuum leak because the lean condition isn't consistent and it idles normally. The misfire only happens while going up a long steep hill when the engine is cold and it doesn't improve/worsen if I downshift. It also doesn't seem to be load based because if I am on the flat I can floor it with no misfires. It seems to have to do with the truck being oriented at an angle when the engine is cold. These two symptoms have me thinking that the line going to cylinder 5 poppet injector may be leaking. I'm thinking maybe on the flat that enough fuel ends up flowing to cylinder 5 to keep it happy but maybe on a hill, when the intake manifold is cold, the fuel that leaks out is flowing away from cylinder five which is causing a lean condition misfire. I'm assuming when the intake cylinder warms up the leaking fuel is more apt to vaporize. However from what I have seen most SCPI failures cause rich conditions so I may be completely off here.
jdbaugh1 is offline
Old 03-20-2019, 09:14 AM
steelmesh's Avatar
Liked 21 Times in 21 Posts
I did the spider injector upgrade on my 99' Silverado 4.3L with 190k miles, had a hard start issue forever and since it was a common failure I just did it, my CEL is on always so not sure if I had related codes lol. It wasn't that bad of a job on a fullsize (because disconnecting those fuel lines). The only bad part is buying that assembly.
Looks like the best deal is on rockauto $208 ACDELCO 2173028 {#89060439} GM Original Equipment; Includes Instructions for Conversion from Poppet-Style Injectors; Includes bracket
Did you do the intake gaskets yet?
steelmesh is online now
Old 03-20-2019, 11:30 AM
I have not. I don't think it's been an issue yet. When it throws lean code I have high fuel trims like 18% -25%. Today my LTFT is steady around 8%. If it was vacuum leak you'd think it would be constant right?
jdbaugh1 is offline
Old 03-20-2019, 11:54 AM
steelmesh's Avatar
Typically the intake gaskets fail at the coolant jackets, so you'd notice a loss of coolant with no leaks, then coolant in the oil. I agree a vacuum leak should be constant, but consider metal expansion too. Do the classic brake cleaner check to see if idle changes.
You should pull the distributor cap and inspect, may as well replace them both anyway if it's been a while. Since it is complaining about Cyl 5, try to visual the plug, otherwise swap plug wires if you got the slack to do it (swap at the cap too hehe).
The following users liked this post: steelmesh
jdbaugh1 (03-20-2019)
Old 03-20-2019, 11:58 AM
Kolt's Avatar
Liked 164 Times in 147 Posts
In... don't know what ive done but my left hip feels like its trying to pop out and my lower back has me crippled. Took me 2 hours to get a car out of my bay that should have only taken 30 min.
Kolt is offline
Old 03-20-2019, 12:07 PM
steelmesh's Avatar
Throw yourself down a flight of stairs...or just visit your Chiropractor they will pop it back into place in a more precise and controlled manner.
Old 03-20-2019, 12:12 PM
ProfDNS's Avatar
Liked 93 Times in 85 Posts
In.
ProfDNS is offline
Old 03-20-2019, 12:28 PM
Liked 2 Times in 2 Posts
In. Find a good chiropractor to fix your back. They are amazing.
michael23v is offline
Old 03-20-2019, 02:05 PM
Kolt's Avatar
I have a really good one and really need to be going about every other week but affording it is another story.
Kolt is offline
Old 03-20-2019, 02:47 PM
Liked 312 Times in 287 Posts
Ive heard that going to a chiropractor kinda just makes you wanna keep going back, doesnt really fix anything unless you continue to go. I crack my own body fo free.
Slowbalt2000 is offline
Old 03-20-2019, 03:02 PM
ProfDNS's Avatar
Do yoga.
ProfDNS is offline
Old 03-20-2019, 03:16 PM
Originally Posted by ProfDNS View Post
Do yoga.
Love yoga, it is fantastic.
Nah, its not something you get addicted to, but like with anything else your body needs "maintenance". You dont just change your oil once.
Old 03-20-2019, 03:24 PM
Kolt's Avatar
It depends on what kind of problem you have whether or not you need to go regularly or once in a blue moon. For me I need to go regularly because I was born with issues with my back and pelvis. I have lordosis and a laterally tilted pelvis.
People seem to get addicted to the feeling of relief afterwards so a lot of people go more often than they really need to. I only go enough to keep myself functional.
Kolt is offline
Old 03-20-2019, 04:21 PM
I feel like there is only so much they can correct unless its just like a temporary bandaid and you have to keep going to stay aligned. Im sure I would enjoy it but I dont like to rely on things.
Old 03-20-2019, 04:28 PM
My personal opinion is that chiropractors are the tarot card readers of the medical world. I've seen them do more damage than good when people have serious injuries. I liken them to massage therapists.
jdbaugh1 is offline
Old 03-20-2019, 04:35 PM
ProfDNS's Avatar
Massage therapy is the ****. Just don't go to a independent office, you can find one that has a governing board and they have to be top notch to stay in that practice.
Same with chiro. I nearly destroyed my left shoulder and rotator cuff from football, and after a year I had most of my mobility back.
ProfDNS is offline
Old 03-20-2019, 06:04 PM
steelmesh's Avatar
Self-cracking is not the same. There is a reason Chiropractors get adjusted by other Chiropractors, because you can't self-adjust.
The reason you need to go back is because you never change your lifestyle and maintain old bad body habits. Also, for example you are sitting at max pain level 7 for years, then you start seeing a Chiro and after 5 visits your max pain is at level 1, then you stop going so then you're back up to max pain level 7 after 9-10 months. What is better, pain level 1 or pain level 7?
In college, I injured my lower back when I was doing auto repair out of the trunk of my car which ended that career. Years later after I graduated, I was a prototype crankshaft test tech, you got it I was lifting crankshafts all day. After a while with this work, my lower back pain kept getting worse to the point of seeking help. I was referred to see the Chiro a stones throw from my work (Goss Chiropractic). My insurance was so good, $30/month for unlimited visits. I went 3x per week for many months, it was so convenient and quick it was easy to make happen and it cured my lower back issues, going on 12 years now. At the same time, I never mentioned it, I could never look down in the mornings this was since I was in middle school, my neck was so stiff it wasn't possible. The doctor observed the issue in my neck without asking and recommended specific treatments for that. I no longer have a stiff neck in the morning.
I injured something in my neck last summer doing main bearing clearances, man handling the LE5 on and off the engine stand multiple times. It got really bad after one day, and I made it worse trying to do self-treatment the next day. Next day I would get very sharp pains depending how I moved or walked. I called in to work and searched for a Chiro. In near pain 9 at short intervals (10 reserved for baby makers), the new Chiro did the neck snapping adjustment (the scary one, hollywood neck breaker move), I did not feel pain from this adjustment. After 4 visits I was essentially fixed, little sore though. 2 weeks ago, my neck started to hurt again, I left it for a day and it got worse. I saw the Chiro and after just 1 adjustment, I felt much better and did not need to go back.
If I wasn't so invested in automotive engineering, I would chose to become a Chiropractor because I believe it works and I would enjoy helping people get better without using drugs and surgery, I'm a rebellious against the system type. Think about it, millions of people see Chiros everyday, and also consider out of the thousands of Chiropractors you're going to get a bunch of shitty ones just like any profession.
Old 03-20-2019, 07:59 PM
Liked 152 Times in 123 Posts
XTSV shopping and hot dogs tomorrow for lunch. Going to be a good day
07MetallicSC is offline
Old 03-21-2019, 07:56 PM
thats a pretty good testimony. i get lower back pain pretty bad sometimes probably from over exerting myself but it always subsides after some time. I guess im just too proud for it at this point in my life. I have good insurance though so maybe I should give it a shot.
Old 03-21-2019, 08:03 PM
Same here I have a pretty weak lower back. Usually cant work to long on cars because I get pain. It gets better after a few minutes of stretching but yeah it sucks . I've never been to a chiropractor either
royce777
The Lounge
31
03-06-2019 06:18 PM
royce777
The Lounge
28
09-20-2018 11:29 AM
royce777
The Lounge
23
12-28-2017 08:14 AM
riceburner
The Lounge
135
04-17-2013 02:27 AM
1BADSS/SC
The Lounge
23
04-07-2010 04:56 PM
Quick Reply: 03-20-19 Why is it Only Wednesday Workchat
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
