The Lounge Off Topic PG-13. Introductions, cars, movies, work, relationships, etc.
04-05-19 Five Friday Workchat
Old 04-05-2019, 02:45 PM
steelmesh's Avatar
Originally Posted by Kolt View Post
That's kinda shady, they shouldn't have needed to do the radiator then and you shouldn't have had to top it off that quickly if they did the vac and fill procedure correctly. What type of coolant did you use? The hybrid system MUST use GM premix 50/50 dexcool otherwise it will eventually cause isolation issues, corrosion, and set codes.
This is why I hypothesize they damaged the radiator. I learned about special GM dexcool working on a Bolt, it requires de-ionized water premixed with the Dexcool. Part number 12378390. I remember because I had it ordered from a local GM dealer, and they sent another type of dexcool with a different part number, so we had to exchange it to get 12378390. I just checked the Bolt GM FSM to confirm that part number. it says "DEX-COOL (Premix 50/50 with Deionized Water)" with that specific part number.
steelmesh is offline
Old 04-05-2019, 02:50 PM
steelmesh's Avatar
Originally Posted by ECaulk View Post
Well looks like I'm going to look into a inline filter setup.
Pontiac Slostices same ordeal, DDM works has a fuel filter kit for the LNF: DDMWorks LNF Fuel Filter Kit
Looks like it is based off the standard GM QD so it would go inline on the LE5 too, not sure if LSJ use this QD at the rail. Can probably build a kit yourself if that is the case
Old 04-05-2019, 03:11 PM
Kolt's Avatar
I don't see how they would have damaged it though unless they over pressurized the system, but even then the weak point there is internal battery connections and the sections themselves. Yep that's the stuff it needs, just wanted to make sure you got the right one. Its bad that even some techs cant wrap their head around not using regular coolant and tap water mix then wonder why the car keeps coming back with isolation codes.
Kolt is offline
Old 04-05-2019, 07:27 PM
Originally Posted by ProfDNS View Post
I'm buying a new set of golf clubs this year. My 5 and 6 iron have been repaired 2 and 3 times each, but the head keeps (literally) flying off.
I got a new set when Nike decided to stop making clubs and put everything on clearance. Got a whole set (4-AW) for $250. Brand new. they have been great for the money.
michael23v is offline
jmfselu
02-04-2009 09:16 AM
wardzach2007
10-10-2008 02:02 AM
nash_darnova
09-17-2007 08:43 AM
CCBalla10
07-27-2007 02:58 PM
Quick Reply: 04-05-19 Five Friday Workchat
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
