The Lounge Off Topic PG-13. Introductions, cars, movies, work, relationships, etc.
06-21-19 Racecar Friday Workchat
Old 06-21-2019, 07:15 AM
royce777's Avatar
Drag strip tonight. Maybe ill run the ATS
royce777 is offline
Old 06-21-2019, 07:56 AM
If you're going you may as well run. Trevor and I got the Cobalt started and idling last night. I may have a charging system problem to track down. I'm hoping that it just wigged out because I had a battery charger connected that was clicking on and off while it was running but who knows. I did leave the signal wire from alternator to stock ECU. If that wire is still connected along with the charging cable I'm not really sure what else I should check. If it comes to it does anyone know how to run and alternator without ECU control?
jdbaugh1 is offline
Old 06-21-2019, 08:55 AM
ProfDNS's Avatar
Heading to St. Louis, MO today, then back to Nashville tomorrow to watch a cousin play some softball then I'm heading back home.
@JD since you're using the original wire, I would just run a multimeter on the wire to make sure you're getting power. I would also check for physical signs of damage.
ProfDNS is offline
Old 06-21-2019, 09:41 AM
So I am running an LSJ alternator that I bought used and like everything I try to source used in "good condition" it arrived with the plastic broken out around where the control wires connector interfaces. When I was cleaning up the stock harness I had no way of being able to tell which wire went to which pin on alternator. I had a 50/50 chance of getting it right and I guessed wrong. I flipped the control wires around and now the system is charging properly. We're all good.
As far as tuning I've only messed with the idle a bit and still have relatively no clue what I am doing but it's kind of fun to mess around with.
jdbaugh1 is offline
Old 06-21-2019, 10:24 AM
royce777's Avatar
Calling all tech people. I need to get a new router and modem. Best products that are for running 2-4 devices. Nothing crazy priced.
royce777 is offline
Old 06-21-2019, 10:26 AM
Keystone?
cw383 is offline
Old 06-21-2019, 10:49 AM
In
Snail_SS is offline
Old 06-21-2019, 10:57 AM
royce777's Avatar
Originally Posted by cw383 View Post
Keystone?
yes sir
royce777 is offline
Old 06-21-2019, 11:40 AM
We need to plan a get together sometime. I might be heading out tomorrow.
cw383 is offline
Old 06-21-2019, 11:52 AM
in. I need to get better tires for my car to race it on a strip.
michael23v is offline
Old 06-21-2019, 12:25 PM
royce777's Avatar
Hell yeah man, You'll have to check out my new ride.
royce777 is offline
Old 06-21-2019, 12:33 PM
Did you get to run yours at the strip yet? ( Royce and Michael both )
cw383 is offline
Old 06-21-2019, 12:50 PM
royce777's Avatar
Nope. I need a tune first
royce777 is offline
Old 06-21-2019, 01:08 PM
exninja's Avatar
5 day work weeks are the worst
exninja is offline
Old 06-21-2019, 02:04 PM
Kinda wanna take my car to the strip but probably best I dont.
Slowbalt2000 is offline
Old 06-21-2019, 03:04 PM
ProfDNS's Avatar
Modem depends on your ISP. Router, you can't go wrong with Asus. I currently run AC2900, but you could go a step down to the AC1900.
Kaboom?
ProfDNS is offline
Old 06-21-2019, 04:03 PM
Stock clutch in the Evo is pretty weak and Im not good at launching. Then add awd on top of all that.
Old 06-21-2019, 04:18 PM
Kolt's Avatar
Kaboom?
may need your assistance if you can help. Make sure I am not missing anything on my end. My internet is still garbage. tech came out and swapped ports on the modem outside, he seemed cool when I was asking about upgrades and the new gig network (we are supposed to get it within a year). Worked fine about 20mi after he left, getting 70-73 down, then it completely cut out. Had the call center reboot/reset the connection. Came back to the 4-5Mbps down. Tech came out while I wasn't there and told my wife nothing was wrong (she said he acted like I was being overly **** about the speed when he came while I was there). Walked her through speed test and still not fixed, getting 4 down, 27 up.
Kolt is offline
Old 06-21-2019, 04:23 PM
exninja's Avatar
Put your purse up and your foot down.
exninja is offline
Old 06-21-2019, 04:34 PM
Thats what the cobalt is supposed to be for. Just gotta finish it one of these years. Ive been practicing my tig welding first.
Old 06-21-2019, 04:53 PM
No not yet. I spent all my available funds getting it where it is at now. Once I am "forced" to replace the tires I will run it. Right now I have no traction till 3rd, and even that is iffy from time to time.
Old 06-21-2019, 05:18 PM
exninja's Avatar
I'm supposed to be here another 2 hours. i don't think i'm going to make it.
exninja is offline
Old 06-21-2019, 05:20 PM
exninja's Avatar
just got 47 wpm, that's 7 better than before!
exninja is offline
Old 06-21-2019, 06:27 PM
That seems pretty low
Old 06-21-2019, 08:14 PM
exninja's Avatar
Improvement is always good. What's yours?
exninja is offline
Quick Reply: 06-21-19 Racecar Friday Workchat
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
