Go Back  Cobalt SS Network > Community > The Lounge
Comercial distributed Audio help >
The Lounge Off Topic PG-13. Introductions, cars, movies, work, relationships, etc.
Old 06-28-2007, 09:03 PM
SS SCHGD's Avatar
So I am looking at upgrading the Audio system in the bowling alley I work at and need some help from a pro. we currently have a 70volt system and a DJ station (with 2 amps and 8 speakers) hooked up to the Amp for the 70 volt system (32 speakers) by a RCA cord and would like to change out the 70volt amp for something better/newer since it's dying.
I'm looking at all new speakers and going to a 4ohm system with a Crown 660A 6channel amp giving me volume control of the 6 channels independently and the choice of leaveing part of the sytem at 70volts. I currently need a RCA input (DJ station) and a XLR microphone input for the system. I will be playing the same thing over 5 of the output channels and just the microphone output over the 6th channel. I believe I need something to change my RCA input into a 5 channel output since the amp has individual inputs for each channel. Something like the BBE DS26 looks promising, but I don't know if it will let me run one input out to 5 of the outputs and the 2nd input (mic) to the 6th output...then again I could just run the mic into the 6th input on the amp.
I also think I need something to change my RCA output into a XLR output for the BBE system. If anyone can give me some equipment ideas or something else I would apreciate it....
(my second option is going to a Russound R1250MC 6 zone amp and finding a XLR to RCA adapter, but I think going with a Crown amp/JBL speaker setup would be better.)
Thanks for any help.
SS SCHGD is offline
Old 06-28-2007, 11:47 PM
tricky1's Avatar
Your best bet would be to just get a mixing board...it's less of a hassle than trying to convert line level to non-line level signals and vice versa.
I have a 6 channel Peavey board I got for $90 at my local guitar shop...it's pretty nice too and would work for what you need.
You can get it here for $89.99 with free shipping
http://www.sweetwater.com/store/detail/PV6/
Sweetwater is the best place to work with...in fact if you call them they give a sales rep that talks to you PERSONALLY and they will give you a DIRECT contact number for that person. So you aren't jumping around between people everytime you call.
tricky1 is offline
Old 06-29-2007, 01:45 AM
SS SCHGD's Avatar
I'm not sure if that will work for my needs, let me find links of the equipment...crown amp
BBE-DS26
adapter
thats bassiclly what I'm looking at...
SS SCHGD is offline
Old 06-29-2007, 02:39 AM
tricky1's Avatar
Okay, so as I read it right now...
You have six multiple zones? as in zones A,B,C,D,E,F so Zone A can have a separate output from Zone B
IE: Zone A is Rock Zone B is Country
OR
Is it ALL zones are the same input/output?
A-F Input = A-F Output?
Because to me that means your going to have to split your out signals from your source(DJ Station) 6 ways for the input as well as your mic 6 ways for the input
I then take it your output would be going to 6 different speakers?
Maybe you could give me a bit more insight on this...
Also for the right price(food and a few games of pool) I could come to DeKalb and check this out for you and see what I can come up with.
Also I just found this which converts the input connector of the amp to an XLR type
http://www.fullcompass.com/product/315134.html
tricky1 is offline
Old 06-29-2007, 03:46 AM
SS SCHGD's Avatar
I'm looking to send one source (our media PC that has everything run to it) and a Microphone to the amp, which will be running 6 zones, A-F with zone F being in the mechanics area. I only need to send the mic to the mechanics area, the music has to go to all other areas. (and each area will have it's own volume control) That adapter is probably what I will need for the Mic to Amp connection and if I use the BBE piece, to go from it to the Amp.
basically
PC-----Distribution processor-----Amp Ch A-----4 speakers
......................|| ------------------Amp Ch B-----6 speakers
......................|| ------------------Amp Ch C-----6 speakers
......................|| ------------------Amp Ch D-----8 speakers
......................|| ------------------Amp Ch E-----8 speakers
Microphone-------------------------Amp Ch F------2 speakers
Thats pretty much it. hope that makes it a little more understandable.
Is this something you do normally?
SS SCHGD is offline
Old 01-05-2019, 10:57 PM
I found a very cool site where a lot of useful information. Also there you can read about bass amps https://musiety.com/a-complete-revie...vox-bass-amps/
Ieng3woo is offline
Old 01-06-2019, 08:15 AM
Mate, this is almost 12years old...the thread not your link.
ECaulk is offline
Extreme Dimensions
09-24-2015 05:24 PM
Turbo6
09-24-2015 04:15 PM
zinner
06-05-2005 06:35 PM
JonyyB
The Lounge
30
03-01-2005 02:48 AM
cvenom2122
01-02-2005 12:02 PM
Quick Reply: Comercial distributed Audio help
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
